Results 1 to 6 of 6
Thread: Resets without reset button? I Hate them
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    Kortrijk/Belgium
    Hi all.
    I have a strange problem. I have a power supply mounted in front of my car. My whole car system works just fine with a normal power supply but with the power supply i have ATX from holland my system works 5 minutes if my didn't drive for 4 hours, then it random resets.
    If i check the motherboard led (power on) it flashes sometimes 10 times and then it stops flashing and the computer starts up. When starting windows or in windows or just after the bios, it resets.
    I think that it resets because of the flashing power led. When i hit reset, then the led goes out so when it blinks i think the power supply just send resets to my motherboard.
    The system works perfect with a normal PS so i think to pu my ps in a metal box to stop the EMC.
    Any ideas what the problem could be? It's sure a problem with my PS but i don't know what the problem is so i'll try to put it in a box first. Hopefully it works and if it don't... help me.
    My car battery is strong enough !
    THX
    Elsewhere
    Sounds to me as if the p[ower geting from the PS to the computer (motherboard, primarily) isn't stable. If it fluctuates too high or too low, it's going to cause what you're experiencing.
    How about the Wiki?
    Nov 2004
    Kortrijk/Belgium
    I measrud 5V,3,3V and 12V and it looks stable to me so that's why i'm thinking about EMC from the alternator or something :s
    Variable Bitrate nzKAOSnz's Avatar
    Aug 2003
    Christchurch - New Zealand
    no - measure the 12v into the psu....
    Nov 2004
    Kortrijk/Belgium
    That's 13.8V when the engine runs and 12.5V when on battery So that's just fine.
    The weird thing is that the problem is gone if the engine is down for more then 4 hours. Then the system works fine for 5 minutes and then i have the problem again...
    Constant Bitrate Trazer's Avatar
    Jul 2004
    The Netherlands
    I had a similar problem when i used an ITPS. In my case it was caused by 2 cooling fans by the radiator wich caused the voltage to drop below 10v (sometimes even below 9v) This is not enough for the ITPS and thus caused the PC to reset/reboot.
    Maybe something like this is happening to you? If i read the specs of the powersupply right the input voltage should be at least 10v.
    To find the problem i removed the pc from the power and connected a multimeter to monitor the voltage on the power line for a period of time. You could try this to see if the voltage drops at a certain time.
    Edit: Seems this is not the problem you're having judging your last post.
    There ain't no need to cry. Time's up. It's time to die....
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  3. ITPS reprogramming ?
    By naruto in forum Power Supplies
    Last Post: 11-26-2004, 02:19 PM
  4. Radio causes system reset after hibination!
    By NotchbackVW in forum MediaCar
    Last Post: 04-04-2004, 05:22 AM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
