Results 1 to 10 of 13
Thread: Stop Press: Faulty Hard Drive Fails to Work
    Constant Bitrate phatbenny's Avatar
    Jul 2004
    Birmingham/London UK
    Hi all,
    I've recently bought a broken hard drive off ebay, it was sold as broken. This might sound like a very stupid idea. It might be, but let me explain my thinking. The people selling them sell tonnes of them all the time. They get them from hardware suppliers technical departments. They don't check them and sell them as faulty with the idea being that some of them are not faulty, because the technical departments will quite often just plug in a new drive rather than waste time trying to fix the old one. So therefore you buy a cheap drive, that may need a little fixing. Here's where you guys come in.
    It arrived this morning so I duly plugged the drive in as a primary master, and the only drive connected on the IDE channel. I think I can hear it spin up and stay spinning. However when I go into the bios to detect it, it doesn't appear. Not only does it not appear, the bit where it usually says [None] next to where it says Primary Master in the bios is totally blank, not even [ ].
    I was wondering if anyone had any bright ideas, as it's quite a good drive other than the not working thing. 40Gb 5400rpm.
    Cheers
    Ben
    Hardware:- VIA EPIA MII 12000 LVDS 1.2Ghz : £137.95 + 512Mb PC2100 DDR Memory : £49.34 + Opus 150w Shuttle PSU: £128 + 7” Lilliput 629 Touchscreen: £173.90 + 2.5” 40Gb 5200rpm Laptop Drive + Slotload Laptop CD-RW/DVD-ROM + Hauppage WinTV-PCI-FM : £53.95
    Jul 2004
    I know, I know.
    It was a bad idea to start with, but I had just been caught up in a load of auction excitement, and before I knew what I'd done I' convinced myself and made a bid.
    Raw Wave Rob Withey's Avatar
    Apr 2000
    Bedfordshire, UK
    Quote Originally Posted by phatbenny
    Good in what way then? As a door stop, or a paperweight?
    If it won't detect in the bios, chances are that it's hosed. Sounds like you got exactly what you bought.
    Jul 2004
    Good as in, if the drive worked it would be a good one.
    Or good as in, if you don't mind the fact it doesn't work then it would a good one.
    Open to your own interpretation.
    Oct 2004
    East Sussex, England
    Gee.. it sounds like it's faulty!!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    check the johnson rod for proper lubrication
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Tell us what model it is and maybe there is someone with a good controller PCB to help you. Those things are not the easiest to troubleshoot you know....
    Jul 2004
    Hitachi 40Gb 5400rpm. Sorry, i don`t have any more details. I`ve left the drive at work.
  1. Hard drive vibration/shock solution? NoiseControl No Vibes
    By slushieken in forum General Hardware Discussion
    Last Post: 08-13-2005, 08:19 AM
  2. Running External Hard drive
    By kickercivic1 in forum General Hardware Discussion
    Last Post: 09-03-2004, 11:56 AM
  3. Ultimate Hard Drive Mount or bad idea?
    By rockthevolvo in forum General Hardware Discussion
    Last Post: 08-29-2004, 05:22 PM
  4. Cold hard drive fluid bearing data loss
    By Mikesz in forum General Hardware Discussion
    Last Post: 12-13-2003, 08:17 PM
  5. Decided to get a fv24, now which hard drive?
    By steve671 in forum General Hardware Discussion
    Last Post: 12-04-2001, 04:50 PM
