Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: J-Link pinout
  1. #11
    suv
    suv is offline
    May 2009
    Quote Originally Posted by kovse View Post
    i think that this will help
    I test it and it works on my JVC with no problem, you just must set on your radio to "line-in"!!!
    Hi There,
    I`m looking for the Unilink pinouts for sony to use as aux input.
    Could someone help ?
    Thanx
    Suv
  2. #12
    Low Bitrate lbergamo's Avatar
    May 2009
    Michigan, USA
    A real handy website to check out is http://pinouts.ru/ . They have pretty much everything.
  3. #13
    Aug 2009
    J-link updated pin out
    I know it's a late update to this thread, but it took me long enough to get the information too. Pinouts are from the labelling on the board itself. I'll be connecting up my cd changer direct this week and will post back when it's all working.
  4. #14
    Newbie After_Forever's Avatar
    Nov 2004
    Quote Originally Posted by SwampyMK View Post
    Were you able to get this working with this pinout?
  5. #15
    Mar 2010
    Works fine
    I didn't have any connectors laying around so i opened up the unit and did some soldering
    was a little trickier with all the weird kameleon motorization and such
    any q's on the process - post me!
  6. #16
    Sep 2010
    JVC J-LINK Changer Wiring
    I just spliced into my J-Link Cable and found that all the pinouts listed earlier are correct. I was able to splice into #6 Right and #8 Left to run to my PDA, and I put a small toggle switch on #1 CONT to shutdown the CD-Changer when I am using the PDA.
    Pin# Wire Color What
    1. Yellow --- CONT
    2. Grey ----- SCK
    3. Green ---- SI/ISO
    4. Black ----- Grnd
    5. Brown ---- +12v
    6. Tan (Red inside) Right
    7. Sheilding on #6 & #8
    8. Tan (White inside) Left
  7. #17
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    toggle switch
    hello,
    I'm trying to create an AUX input into my hold JVC Car Stereo.
    It has a CD Changer with J-Link connector.
    I've bought a simple adapter with only J-Link connector at one side and RCA connectors at the other side (no unit logic), but when I plug an external input insted of the cd changer, nothing happens.
    I think that it's needed a switch to enable the input signal as the CD-Changer do.
    could you explain the way to connect the CONT pin ? I have to connect it to the ground or to the +12V ?
    Thank you.
    luigi
    CarPC in Progress [||||||||-] 90%
    Visit my Project
  1. ugh.. why didn't someone tell me my link was messed up
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-16-2004, 06:45 PM
  2. Request to change link for MP3Car Logo
    By frodobaggins in forum Mp3car Forum Suggestions/Comments
    Last Post: 01-28-2004, 02:15 AM
  3. LCD pinout help
    By lewbar in forum LCD/Display
    Last Post: 08-22-2003, 11:09 PM
  4. Datalux M1023 controller pinout?
    By Odie in forum LCD/Display
    Last Post: 10-11-2002, 05:07 PM
  5. Replies: 5
    Last Post: 03-18-2002, 03:30 PM
