Results 1 to 3 of 3
Thread: mobo grounding question...
    _
    Mar 2004
    Little Elm, Texas
    Question mobo grounding question...
    Ok, so I can see the need for grounding your mobo when you are using an inverter in the car to get power to the mobo; but what about when just using a dc-dc psu? Especially since the ATX plug has quite a few grounding wires....
    When using the inverter you are taking dc to ac then back to dc, which could cause a floating ground, right? Ok so when you have dc-dc that floating ground isn't an issue, right?
    so then would it be necessary to ground your mobo when using dc-dc??
    just something we've been pondering since the last install.....
    Jan Bennett
    it is grounded through the wiring harness. i have an MII10000 with an Opus 150 and it isn't grounded other than connecting the black wire (off power supply which goes to ground)
    _
    Mar 2004
    Little Elm, Texas
    ok - so then a seperate ground isn't really needed when using Dc-Dc?
    cool, not that it's a big deal this time around, just something we had been wondering about for a while now
    thanks!
    Jan Bennett
  1. Quick grounding question
    By GingerPrince in forum Power Supplies
    Last Post: 11-06-2004, 09:28 PM
  2. Grounding question.
    By barney0001 in forum General Hardware Discussion
    Last Post: 09-23-2004, 11:43 AM
  3. Properly grounding mobo
    By BMp3W in forum General Hardware Discussion
    Last Post: 11-17-2002, 10:50 AM
  4. FV24 grounding question
    By Squeezer in forum General Hardware Discussion
    Last Post: 03-21-2002, 05:06 PM
  5. mobo grounding
    By ppgt94 in forum Power Supplies
    Last Post: 05-23-2001, 10:20 PM
