Results 1 to 4 of 4
Thread: A-Tech 5000 HP Media Center Case
    Feb 2004
    Cool A-Tech 5000 HP Media Center Case
    OK, this is slightly off-topic in that it wouldn't go in your car, but it's still worthwhile to look into for a case to build a Home Theatre PC in.
    A-Tech Fabrication has an all-aluminum HTPC-style case that has some really cool options:
    • Front-mounted Xenarc 700TS LCD touch-screen display.
    • Front-mounted character LCD display.
    • Front-mounted Griffin Powermate USB dial controller.
    The case starts at $395, though, and a fully decked out case will run you about $1000, and that's without the $400 Xenarc 700TS.
    See here:
    http://www.atechfabrication.com/products/atech_5000.htm
    http://www.atechfabrication.com/atec...order_form.htm
    This case has a lot of options in common with a CarPC..
    Nice.. and expensive!
    _
    Mar 2004
    Little Elm, Texas
    very nice!
    I absolutely LOVE the aircraft grade 6061-T6 heat-treated aluminum alloy!!!!
    I might have to put this on my wish list!
    Jan Bennett
    Feb 2004
    Quote Originally Posted by Red GTi VR6
    very nice!
    The coolness doesn't stop there, either..
    Check out the REST of their HTPC cases:
    http://www.atechfabrication.com/HTPC_cases.htm
    The Mass Storage Case at the bottom is especially cool (pun not intended), it's an external 1U-size hard drive case that is passively cooled, and can hold 4 hard drives.
    Jul 2004
    why don't you just show then the best of the best
    http://www.atechfabrication.com/prod...en_display.htm
  1. windows xp media center edition
    By the_spy_guy in forum XP MCE
    Last Post: 04-15-2006, 03:26 PM
  2. Sirius/XM Satelite Radio in Media Center!
    By nFiniteTuning in forum Software & Software Development
    Last Post: 12-07-2004, 11:12 PM
  3. FFGSK CAR Media center V1 - or: my project :D
    By felix99 in forum Show off your project
    Last Post: 10-08-2002, 02:25 PM
  4. Windows Media Center
    By nxt125 in forum Software & Software Development
    Last Post: 07-30-2002, 02:25 PM
  5. HP Omnibook 5000 LCD to be converted..eventually
    By titanx in forum General Hardware Discussion
    Last Post: 09-27-1999, 11:48 AM
