Results 1 to 5 of 5
Thread: Ok setup? What Power supply?
    Dec 2004
    Arrow Ok setup? What Power supply?
    Ok, Im working on getting my carputer setup. Its gunna be used mainly for running dsmlink (a management/tuning device for dsms) and play mp3s. Probably will be used occasionly for dvds and cd burning, not to much game playing, and may setup a gps and radio/tv tuner at some point. Im wondering if this setup is ok, check out my wishlist. Newegg Wishlist I will be making my own case out of plexi glass (unless I can find a decent really small case I like) and then probably carpeting it (will make holes for proper ventalation), and placing it in the glove box. How does this setup look? Missing anything? Any recommendations?
    My other question is powering it. I will also be using a lilliput 7 or 8in touchscreen lcd. I was going to get the opus 90watt, but I wasnt to sure if it would be enough. Is there some other powersupply I should look into? The powersupply and regulator setups arent really to cheap and I dont want to have to spend a fortune on one if I dont have to.
    One more thing, I believe the external cdrom/burner will have to be powered off the PS as well and cant get power from just the USB? Correct me if im wrong.
    Sorry for being kinda long and thanks for any help!
    - Nick
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by untal3nted1
    Can't say anything about the MB or Processor, I'll let someone else comment on that.
    I got the Opus 90W, works great. I wish however I would've got the 150W, I now am starting to strain my 90W. You'll find once you get going, you won't stop. You'll allways be adding something else.
    I would alsospend the extra and get the Xenarc, much nicer and seems to be of better quality.
    This is correct, most likely 5v.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Dec 2004
    Thanks so much for your response. As far as the Xenarc and lilliput goes, is there that much of a difference that you know of?
    Like I said before, im trying to spend as little as possible and not go overboard. As far as adding on, the only thing I may do is addon a GPS and tv/radio tuner at some point, so I dont want to spend anymore then I have to for this carputer. Ill be spending it on major performance modifications. The carputer setup is going to be used mainly for my engine management and for playing music, music vids, maybe some dvds and burning cds on the fly.
    Anyone have any other suggestions? Comments on the setup in my first post?
    Thanks again for your help.
    - Nick
    Super Moderator xBrady's Avatar
    USA
    IMO that is an absolutely perfect setup except for one thing. I love the MB, CPU, Media drive but if you want to cut down on the cost I wouldn't go for a notebook drive. They cost a lot more for a lot less space and it would be very rare that a notebook drive would have any less problems than a non-notebook drive. 40GB isn't nearly enough for me, but that's just me.
    Installed.
    -GPSSecure- - GPS Tracking
    Dec 2004
    Quote Originally Posted by brady
    Wow thanks for your input, wasnt paying attention to that price difference. I had just read how those drives use so much less power, after looking though, forget that. I changed to a normal size 80GB WD drive for almost half the price and more rpms haha. I also just decided to forget about the OPUS 90w and just get the 150w. Thanks for your catch.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
  3. Replies: 5
    Last Post: 06-16-2004, 01:41 PM
  4. 350 watt power supply
    By MasterJacko96 in forum Power Supplies
    Last Post: 01-20-2004, 05:01 PM
  5. Alright, Gonna make my own power supply.
    By crazydemon in forum Power Supplies
    Last Post: 01-18-2004, 06:36 PM
