Results 1 to 10 of 13
Thread: Converted 3.5" HD to External USB
    Variable Bitrate PaCMaYNE's Avatar
    Aug 2004
    tx, USA
    Well i havent had any time at all to figure out the current small prob im having,,
    but before i tried a few more things i figured id ask if anyone might know. Straight to it..
    I made a USB hard drive out of a normal 3.5" 120GB hard drive, it was working fine while i had it directly connected to the USB slot on my EPIA M10k, now i have a USB 2.0 HUB connected and the HD now goes through that and the BIOS freezes right before IDE check, i changed a few BIOS options like only boot from IDE, not to boot other devices ect, but still nothing, if anyone has any suggestions let me know, otherwise ill eventually figure it out.
    throw a moon
    heuvos vin chevos
    FLAC Chairboy's Avatar
    Jan 2004
    A troubleshooting step to try: Does unplugging the drive from the hub fix the problem? Just because that's the last thing you remember doing doesn't necessarilly mean that it's what broke. Just confirm whether swapping between the hub and direct connect is THE thing that causes it to go between broke and fixed.
    Second, are you trying to boot off this drive?
    Chrysler 300 - Fabricating
    http://hallert.net/
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Yah, go back to the original config to see if it still works. Is the USB hub powered?
    Aug 2004
    tx, USA
    yea, currently when i get in my car i have to unplugg the USB HD let the BIOS boot, then plug back in the USB HD, yes it still works if i bypass the HD and go direct into the USB slot, yes the USB is BUS powered and external powered, i have to have it external powered so i can use my GPS mouse
    throw a moon
    heuvos vin chevos
    Aug 2004
    tx, USA
    yea weird i know,, i need 4 USB slots on the M10k
    throw a moon
    heuvos vin chevos
    Jul 2004
    Rancho Cucamonga, CA
    My guess would be that the hub does not have quite enough power for the hard drive.
    EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
    My Truckputer
    Aug 2004
    tx, USA
    PEOPLE NEED TO READ POSTS FULLY
    thanks though fellas
    throw a moon
    heuvos vin chevos
    Jan 2004
    And YOU NEED TO NOT BE A JERK TO PEOPLE TRYING TO HELP.
    dang
    http://hallert.net/
    Aug 2004
    tx, USA
    i was not being a jerk, and my statement was obviously not directed towards you,
    quit getting so defensive
    "Tr1999999999991N"
    throw a moon
    heuvos vin chevos
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    Did you use an USB2.0 cable?
  1. Guys with External USB sound..........
    By camsgs3 in forum General Hardware Discussion
    Last Post: 12-03-2004, 11:57 AM
  2. FS:60 laptop slim hdd w/ external usb 2.0 case
    By e36mp3 in forum Classified Archive
    Last Post: 11-16-2004, 04:05 PM
  3. Replies: 6
    Last Post: 07-21-2003, 03:18 PM
  4. No Firewire in my BookPC / USB HD??
    By PoBoy in forum General Hardware Discussion
    Last Post: 06-12-2001, 08:38 AM
  5. USB HD
    By Old El Paso in forum General Hardware Discussion
    Last Post: 01-13-2000, 12:59 PM
