Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: HELP! I Screwed up!
    Oct 2003
    HELP! I Screwed up!
    OK guys, I'm an idiot. I reversed the polarity on my xenarc screen, and now it won't power up. Any ideas on what kind of damage I caused, and what can be done to fix it? Is it just a small peice, or did I fry the whole damned thing? Any way I can fix it myself? PLEASE HELP!
    THANKS,
    Dan
    _
    Mar 2004
    Little Elm, Texas
    bump - since I would like to know what others have to say on this as well....
    thinking a diode might be messed up????
    Jan Bennett
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I wish I had the answer, but I don't. I just wanted to say, it's been my experience every time I've done this that it just didn't ever work right after...
    Tidder
    Try RevFE
    Maximum Bitrate Altimat's Avatar
    Oct 2003
    WI
    I'm sure there is a fuse. Call Xenarc their support is great.
    Fabricator
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    If it is designed properly, there would be a sacrificial diode after the fuse and the diode will fry and the fuse will blow. Replacing the fuse and the diode will fix it.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Cross your fingers and open it up...youll see something im sure.
    Once you let the smoke out, its hard to put it back in! You did save it, right?
    2005 Ford Focus ST
    _
    Mar 2004
    Little Elm, Texas
    it's already open - there was no front part to the case....
    I also don't remember seeing an internal fuse in there, at least not a fuse in the traditional sense.....??
    there is no plug on the power lead being that it was cut off to hard wire it into the car the first time...
    I know this because I sold him the screen.....there was a note on the plug wire to tell him which lead was positive and which lead was negative
    Jan Bennett
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Fuse can be of SMD type. Its hard to recognize, but it should look transparent and "small sized" )
    _
    Mar 2004
    Little Elm, Texas
    right on - right after I posted that I rememberd something about that size/type of fuse.....
    does anyone know where it would be located? or where abouts? like close to where power would enter the board?
    Jan Bennett
    Oct 2003
    Thanks for the help, guys....I'm looking, but I don't see anything burnt out or anything that resembles a fuse. I will try a magnifying glass and see if that helps. I hope you guys are right about the fuse - there was no smoke or pops or anything whatsoever when I plugged it in wrong....
    Dan
  1. Opinions/Ideas: Possible screwed Lilliput
    By Magma in forum LCD/Display
    Last Post: 10-30-2006, 11:59 PM
  2. I think I'm being screwed. Help
    By Rob in forum Off Topic
    Last Post: 06-26-2002, 12:30 AM
  3. 4 x 20 LCD screwed up.
    By knix in forum LCD/Display
    Last Post: 06-04-2002, 05:56 PM
  4. Screwed up sound
    By Dartman111 in forum General Hardware Discussion
    Last Post: 05-11-2001, 04:56 PM
  5. Hard Drive screwed in cold weather!?!!?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-23-2000, 12:41 PM
