Results 1 to 10 of 10
Thread: Caps Horror...
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    Exclamation Caps Horror...
    Be sure you check your Epia for deformed/blown caps...
    http://www.epiacenter.com/modules.ph...rticle&sid=450
    _
    Mar 2004
    Little Elm, Texas
    wow - that's a suck......what exactly would happen if this happened? would your comp crash on you or just start acting weird?
    Jan Bennett
    Jun 2004
    I have another motherboard that has about 8 that look just like that. I am in the process of replacing them. The computer (a thin low power low heat device) started acting odd, rebooting, hanging, hanging while booting, and unresponsive. I opened it up to add an SODIMM stick of ram since it only had 64 megs (added 128) and noticed all the caps bloated and leaking. Pretty easy to replace them on this device. I had another board that was succeptable to that problem, I think made my PC-Chips. I haven't seen anything like that on my ME6000, but will watch it, however it will be tough when it is finally mounted in its final spot in the car.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    simply replace with same specs caps will fix the issue, or it shall be return to wherever it was made?
    -Mars
    Jun 2004
    I think it is an issue with the caps themselves, not something with the mobo or powersupply that causes them to expand and leak. Replacing them should be all thats needed.
    Jun 2004
    Athens Greece
    Quote Originally Posted by Bangster
    That's true. GSC caps are not of good quality and in some cases (posted on the viaarena.com forums) they have a 100% failure ratio
    So when you observe odd behavior of your epia just include the caps check to your checklist...
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Interesting story about this here:
    http://home.earthlink.net/~doniteli/index27.htm
    My friend has replaced caps in several boards and is sending an Intel MB back for RMA due to puffy caps.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Cheap caps are used by cheap manufacturers
    Constant Bitrate Hell-Stopper's Avatar
    Oct 2004
    hehe happened too me a long time ago....replaced my old board with panasonic caps...still working like a champ ....so true its not even funny.......at least the caps are abit better now a days..
    Feb 2004
    Montreal
    reverse-engineering capacitors is just wrong... use genuine caps for your electronics... LOL
    -Mars
  1. Replies: 13
    Last Post: 12-09-2004, 06:47 AM
  2. DVD Drive Horror!
    By c0rrupti0n in forum General Hardware Discussion
    Last Post: 10-30-2004, 03:30 PM
  3. WTB: Caps for a Tank Circuit
    By surfer6262 in forum Classified Archive
    Last Post: 11-09-2003, 01:36 PM
  4. Why do sum Sound systems hav huge caps ?
    By X-treme in forum General Hardware Discussion
    Last Post: 09-27-2001, 08:16 AM
  5. AC phase correction caps ?
    By Axkicker in forum General Hardware Discussion
    Last Post: 12-10-2000, 09:47 AM
