Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 77
Thread: 400$ computer
  1. #21
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    I'd go with:
    http://www.newegg.com/app/ViewProduc...130-471&depa=0
    http://www.newegg.com/app/ViewProduc...131-504&depa=0
    http://www.newegg.com/app/ViewProduc...128-208&depa=0
    for the celeron. Its got build in graphics and stuff...
    Also, build you own case! Save money!
  2. #22
    Constant Bitrate BeaverWise's Avatar
    Oct 2004
    Germany
    Just remember that if you go with a Via solution that you can't get the native resolution for most 7" monitors out of the onboard video. And you will probably come to find out, as I did, that the onboard audio won't cut it! After I bought the Via MII 10000 I discovered this, solution being to run powerstrip and buy an Audigy 2 NX. And this was after lurking for about 4 months on the boards.
    Great questions and do your research before you buy!
  3. #23
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I also see no way to power drives.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  4. #24
    Jun 2004
    Massachusetts
    I mean, doesn't the ITPS cut it down to 60watts? Not enough for what you've got planned.
    ,./(0)3
  5. #25
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    That 400 buck is for the PC, you have to spend another 300-600 for LCD VGA monitor.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #26
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Anyone got any views on this mobo from MSI? http://www.msi.com.tw/program/produc...il.php?UID=619
    I am after a uATX with firewire for DVD as i don't like USB2 for streaming (and the SATA might be nice for a hot pluggable HDD). I looked at the nforce info site (http://www.nvidia.com/object/motherboards.html#msi) and it says the MSI K7N2GM has GF4 MX graphics but this is the K7N2GM2 although i suspect it is the same but just doesn't say. There are also Albatron and Aopen boards with GF4 MX graphics but i am having trouble locating them in the UK. Incase anyone is wondering i want these grpahics as they should be able to get 800x480 and the ASUS A78X-VM has no manual CPU settings and the biostar has had issues with OPUS. I don't know if the boards i have mentioned have full CPU control except the MSI does have FSB control i am just not sure about multiplier.
  7. #27
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Scouse Monkey
    Yeh, that a good motherboard
  8. #28
    Jul 2004
    Berkeley, CA
  9. #29
    Mar 2004
    Bristol
    Quote Originally Posted by 0l33l
    i thought so. MSI manual is very good but doesnt say if the manual settings include multiplier. My desktop has an old Abit BE6-II so i used to having software CPU control so it seems wierd when i work on bioses with no manual control. Can pick upt he board from loads of places for arounf £50 and has everything i will need (can upgrade the crappyish on board graphics later but to be honest they will be fine as i wont be gaming and should be perfect for getting 800x480). I will be adding a PCI or USB2 soundcard and using the on-board for GPS and phone with headrest mounted speaker and mic. Jus tneed to find out if it will take mobile athlon ok (looking for older 2400 or slower as 2500 is around £70)
  10. #30
    May 2004
    How would i go about this? I mean what kind of materials do you suggest? I bet i could cut apart all the insides of my old computer to help me make a new case, but the most important thing for me is to get it small and with a dc-dc psu. I wouldnt mind gettin an OPUS, but i know thats cutting out nearly half my budget.
    If i was to get an OPUS, what kinda spec comp could i run with the 90 watt psu? if i had to pay 200 bucks for the 150, thats quite a bit of money. wouldnt leave much for case, mobo etc.
    Quote Originally Posted by EBFoxbat
    Wait, are you saying that the psu wont supply power to everything?? im soo lost right now pleas ehelp
    And you said ITPS cuts my power to 60 watts, that wont do. How do you suggest i go aobut powering this computer. It seems that psu is the hardest part for me...and the more i hear, the more i think i need to spring for an OPUS.
    Quote Originally Posted by MatrixPC
    I already have the monitor. I am already using an old computer in my car and it works, I am just trying to upgrade it to a smaller/faster computer.
    This mobo looks like it has everything. I might check into the pricing and see if itll work for me. id still need a processor which would be like 75 bucks. then an opus which would be 200 im assuming. Then a case i would build. Dunno what kind of materials needed for that. Cant think of anything else i would need off the top of my head. This building my own box idea is sounding better and better....
    Please continue replying to this thread as i need help and the help you guys have given me so far is invaluable.
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 09:51 AM
  2. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 01:05 PM
  3. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 02:14 PM
  4. computer remote control
    By agent_86 in forum General Hardware Discussion
    Last Post: 10-18-2002, 02:36 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
