Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 77
Thread: 400$ computer
  1. #31
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Get the Opus 150 or a 300 Watt ATX PSU and an inverter.
    Or get an OPUS 90 and design a system that will run off that.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  2. #32
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I am trying to find out if the MSI has user definable CPU clock settings. So far it looks like ypu can do fsb but not mulitiplier. I still like the idea of the ASUS as it has the personal boot screen option which would be very cool but the wire mod is really putting me off - especially in a car environment.
  3. #33
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I got a Dell with a 2.4 processor, 256 mb ram, cd burner for $300. Check the small business section, they have better deals there. Also check the "outragous deals" under small business.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  4. #34
    Maximum Bitrate CJ8501's Avatar
    Jul 2004
    Orland Park, IL
    Quote Originally Posted by Slitha
    This mobo looks like it has everything. I might check into the pricing and see if itll work for me. id still need a processor which would be like 75 bucks. then an opus which would be 200 im assuming. Then a case i would build. Dunno what kind of materials needed for that. Cant think of anything else i would need off the top of my head. This building my own box idea is sounding better and better....
    Please continue replying to this thread as i need help and the help you guys have given me so far is invaluable.
    How bout some ram and a hard drive starting with that? And possibly a sound card, but you can always use the onboard sound, same with the onboard video. I say your lookin about
    70 for a Micro ATX mobo
    75 for a Processor (probably a celeron) try Ebay
    40-60 for a hard drive
    40-60 for 256-512 ram
    200 for the opus
    about $465
    That seems pretty good especially if you build your own case and have your own optical drive....
  5. #35
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    90 is not nearly enough for even a celeron. 90w Opus is good for EPIAs.
    Go with the inverter/some shutdown controller from the mp3car.com store. It will be cheaper for you. You'll still need a PSU. And yeh, gut the old case
  6. #36
    Jun 2003
    Memphis - TN
    Walmart.com has a $200 PC w/ linux.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  7. #37
    Jun 2004
    Massachusetts
    why do you want to change the multiplier ?
    ,./(0)3
  8. #38
    May 2004
    Quote Originally Posted by CJ8501
    200 for the opus
    about $465
    I have a 40 gig. harddrive i can use already.
    Im not sure what an optical drive is...
    Quote Originally Posted by 0l33l
    The inverter just isnt workin for me...Ive had 4 crap out on me. Granted I kept returning them and it didnt cost me mor ethan once, its still not reliable enough for me. I want a strong comptuer that i can rely on always working and can upgrade to GPS when the time comes. I need to resesarch more on mini mobos. Ill do that tomorrow n check back.
  9. #39
    Jul 2004
    Berkeley, CA
    Then you can't have a powerful computer because the OPUS can only supply 150w... until the 220w version comes out.
  10. #40
    Oct 2004
    Spend the money on a good inverter and you wont have that problem. Motorhomes use these things as OEM equipment. If you go to an RV store they should have some pretty good ones. I got mine from COSTCO, but it's not a usual item for them. It kicks ***.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 09:51 AM
  2. Cutting power to USB after computer has shutdown
    By lookinco in forum Power Supplies
    Last Post: 05-17-2006, 01:05 PM
  3. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 02:14 PM
  4. computer remote control
    By agent_86 in forum General Hardware Discussion
    Last Post: 10-18-2002, 02:36 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
