A similar thing happened on my EPIA 800, it defaulted to TV Out - had to connect an old 5" Composite TFT alter bios settings and reboot - worked fine after.
Hi,
well i thought i'd update the bios, downloaded the things from the site all went well updated succesfully (atleast thats what it said) press F1 to restart, restarted... no vga signal my lilli says, so i think oh ok a res/rf rate my lilli can't handle but no signal on my normal crt either??
what happend? maybe anyone here can help i'm puzzled.
will it help to take out the battery on the mainboard to reset it?
thanks in advance
my destinator map resource down permanently
hmm thanks for the reply, nut isnt working for me, only composite screen i have is my tv, and that isn't responding on both my s-video as my rca
but i'm off to bed now its almost 0400 here had enough of it :P will read any replies in the morning thanks in advance
Maybe the BIOS defaulted in some weird settings. Try to do a CMOS reset or use an old PCI graphics card and setup your BIOS.Originally Posted by GReeToZ
Good luck
I actually had this problem with my Via Epia m900 a few months back. I couldnt get the newest display drivers unless I updated the bios, I did and it said everything had gone through flawlessly. Upon restart the motherboard wouldnt post. I couldnt even get into the bios settings! If you check onthe viaarena.com forums there are a few posts about this situation happening a few times. I ended up writing via 2 nasty emails and leaving 2 ****ed off messages and 2 days later at 8pm someone from god knows where called me back, gave me an rma, and i sent the package to cali, a month and a week went by and I called again asking where the hell the package was and what the deal was. They told me it had just gotten there and would be looked it, 4 days later I had it in my hands, turns out they sent it to tiawan or something- and all they did was replace the board! But hey, I'm tickled pink about the new board. If you arent pressed for time, write some emails and call some poeple and you should be able to get a new board outa them, or atleast some repair so it works again. Good luck!
-matt
Reset the Bios. Pull out the CMOS battery, and move the jumpers to the clear CMOS position. You''l be able to enter BIOS then. I have to do this everytime when I want to enter my M10000's BIOS. Otherwise, pressing "DEL" won't do anything...Wierd ha...
And connect CRT instead of LCD or vise versa. 1.16 does sets very strange timing for VGA port. Let me know if this works for you, just curious.
i went to the via forums and there is a prob with the new bios, also that it doesn't output vgaOriginally Posted by mpattonm
put in a ddr2266 ram in it and cleared cmos and booted again but when i put the share vga mem to 64 instead of 32 it doesn't output vga again think they need to work on that 1.16 bios...
do you get any display at all ?
I had an issue last night where it posted, said DMPI update suceeded then hung, ended up I had to re-seat my HDD cable.
Cheers,
Grant
'03 Corvette Z06 - car pc soon
'99 Eclipse GSX
'03 Ducati Monster
Not sure what EPIA you have, but I know with a BIOS update you also have to install the VGA drivers with it..
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
