Results 21 to 30 of 35
Thread: Dodge Ram 1500 (Hemi) carpc
  1. #21
    Constant Bitrate pirate_king00's Avatar
    Jan 2005
    SlangNasty,
    No I did not try using the stock speakerwire, however I am using 12 guage wire for the speakers. I did not want to cut my speaker connectors off just in case I ever decide to sell truck and put stock system back. My carputer system is 100% totally re-wired. If your new speakers sound good with the stock wires than I would leave it alone. I hope to have pics off my install up this weekend, you will see how I ran my new wires. I only had to drill holes for the rear doors. The front had exisitng holes.
    What sub box did you go with? I used a qlogic, but I may be having someone build me a custom fiberglass box for my JL10w3v2.
    My system is working great, no problems since its been done for about 3 weeks.
  2. #22
    Feb 2005
    Arrow Hmm .. progress?
    You done with the project yet? Any good pics?
    But most importantly, how is that power supply workin` forya`?
    I've just completed my install (90% .. have to camuflage everything) and running it with an inverter (bleah!). I am running a p4 2.8 on a uATX Intel board and I have many devices on it. I need plenty of juice but I think 200W should do it. So any input on that PSU would be great! And plus .. what a price difference ei?
    OPUS 150 - $179.99 (woo .. discounted)
    M1-ATX DC-DC ATX - $79.95 (this one's got a shutdown controller on it)
    PW-200-M - $49.95 (w/o shutdown controlloer, I believe this is the one you bought)
    http://www.mini-box.com/s.nl/c.ACCT1...category.13/.f
    Also, any ideas for the shudown controller?
  3. #23
    Mar 2005
    kansas
    Pirate King,
    Can you let me know how that power supply works out for ya? I plan on using a similar setup and was thinking of that power supply for it. I was told by many that a p4 2.8c was way to over powered. Glad to see people are a little more supportive on this thread.
  4. #24
    Constant Bitrate slangnasty's Avatar
    May 2004
    San Diego
    I am running an OPUS 150. I got it setup so that on turn-of-key my CarPC boots up and 20 seconds after I turn the key OFF the OPUS automatically powers down my CarPC. Works great!
    my two cents.
    - CarPC install complete.
    - CarPC software: CENTRAFUSE
    - Planning/working on in-dash for lilliput monitor
  5. #25
    May 2004
    San Diego
    Quote Originally Posted by pirate_king00
    SlangNasty,
    Not running a sub... (yet ). For the time being im running a 8-speaker setup.
    In the front floorboard: I installed the Q-Form Kick panels, mounted with Infinity Kappa 50.5 Component speakers.
    In the front doors: i removed the old 6x9 and installed Kicker 8" Midbass speakers (they rock!).
    In the rear doors, I replaced the old speakers with Kicker 6 1/2 2-way speakers.
    Amps: The front component speakers and the rear doors speakers are powered by a 4ooW sony explode amp. The 8" midbass speakers mounted in front door are "free-air" woofers and provide my low end bass powered by an AudioBahn 100W 2-channel amp.
    I also upgraded my HU to a Clarion ProAudio... so the front, rear, and sub audio channels are all pre-amp out to my amps and then channeled to the 8-speaker setup.
    The next speaker upgrade will include a sub. Not sure what I want in this category, but I am definately open to suggestions.
    Any suggestions?
  6. #26
    Jan 2005
    Right now I am using an inverter, I am going with carnetix powersupply when it comes out, however my monster inverter runs great. The ps for my pc is 200watt and I use that to power all my devices. No problems. I will be posting pics this weekend, who know maybe tonight I will get some more pics.
  7. #27
    Feb 2005
    Dude, an inverter ... really? No noise problems? I was having some of those, but I got them sq`ed away by grounding a couple of things and installing couple of chokes. Do you have a true sine invertor?
    Also . . . those pics would be spiffy !
  8. #28
    May 2004
    San Diego
    Im running an opus and have some noise in my audio. Any recommendations for a noise filter?
  9. #29
    Jan 2005
    logikop> My inverter is from Monster audio, I had noise at first but grounded it to my ground on my vehicle (try to stick with one grounding point for everything). I have no noise filters running what so ever, you should be able to accomplish the same goal. If you have problems im me with a phone number and I can possibly help you out over phone.
    Slangnasty,
    I bet if you bround your Opsus case to your grounding point that your noise will go away. Also how did you run your power wires/speaker wires/rca wires? I have power on Drivers side of Dodge, RCA cables on passeneger side, and my speaker wires come up the middle. I kept everything away from the power cables (in my case 4guage wire).
    Let me know if any of you Dodge guys need some help. I will be posting pics this weekend, gonna take a few more pics. I plan on throwing up a website soon as well, with hardware recommendations and tuttorials. Everyone on the form like to make people search and read (not a bad idea but can be time consuming, took me about 3 months to come up with everything, and make sure software was going to work). It all payed off, just wanting to help out other
  10. #30
    Feb 2005
    Wink
    lojikop> My inverter is from Monster audio, I had noise at first but grounded it to my ground on my vehicle (try to stick with one grounding point for everything). I have no noise filters running what so ever, you should be able to accomplish the same goal. If you have problems im me with a phone number and I can possibly help you out over phone.
    Thx, but that's how I fixed my noise issues in the 1st place...and works like a champ! The key is, like you said, sticking to one ground point for most of your crap (i.e. no ground loops). You can *easily* achieve by using a distribution block for your grounds (i.e. buy another power distribution block and use if for your grounds). The chokes were installed subsequently... because I noticed an improvement in quality, however I think itís more psychological than physical !
    Amen to that brother . . . as long as itís not crap questions (e.g. Do I need to power my carputer, or will it just run on good karma?), I am willing to help as well.
  1. 2003 Dodge Ram 4x4 Laramie
    By GinoRP in forum Show off your project
    Last Post: 05-21-2008, 12:10 AM
  2. Progress....Dodge Ram in dash Lilliput
    By Wolfman in forum Fabrication
    Last Post: 03-17-2005, 03:00 AM
  3. Dodge Caravan CarPC installed
    By vision in forum Show off your project
    Last Post: 11-20-2004, 10:16 PM
  4. 1996 Dodge ram 1500 EXTended
    By chuckctv in forum Show off your project
    Last Post: 10-03-2004, 09:08 PM
