Results 1 to 5 of 5
Thread: REplacing motherboard...problems?
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    Allright I'm replacing my dead motherboard with a different board.
    How much hassle will this cause? The motherboard will be the only new part. Same RAM, same processor, etc etc etc. Should WindowsXP load up fine? Or will I have to re-install it?
    Aug 2004
    Should load fine since hard drive will be the same, and that contains XP. However just make sure you get right type of mobo since some support different types of RAM
    Dec 2004
    Baltimore, Maryland
    Thanks!
    Constant Bitrate b_nom's Avatar
    Houston, TX
    I'd recomend you reinstall windows, because:
    1. more than likely your new mobo will require a whole different set of drivers
    2. unless you have Windows XP Volume Licensing edition you will have to re-activate your windows install because windows will "think" you tried to copy you original windows installation and put it on a different PC. More here and here
    This site and this site gives you a bit more insight on how to do it
    He's talking about the different types of RAM: SDRAM, DDR RAM, RDRAM. Verify which one you have and if it will work with the new mobo you intend to buy.
    '96 Chevy Cavalier - EPIA M10000, Win2K,MediaCar, Deluo GPS Mouse with Routis, 60GB external HD, 7" widescreen monitor from DigitalWW.
    '00 Jeep Wrangler - planning stage
    What can BROWN do for you?
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    You will need to reinstall windows, I know this first hand. Unless its the same kind of motherboard or a very very similar one it will have a different chipset. And if windows will try to load up with the chipset it was installed with it wont work. Mobos are really the only thing that makes you have to reinstall windows. Sorry dude.
    EDIT:
    He said he was using the same ram. And its very hard to find rdram and sdram these days. Its cheaper to go with ddr. ddr2 is so pointless right now. /random fact heh
  1. New motherboard and now problems!
    By nick9871 in forum General Hardware Discussion
    Last Post: 10-20-2004, 04:51 PM
  2. Dell Inspiron 8200 & Lilliput TS problems?
    By bkpsu in forum LCD/Display
    Last Post: 08-15-2004, 02:55 PM
  3. Replies: 109
    Last Post: 05-31-2004, 10:07 PM
  4. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  5. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 08:56 PM
