You should just be able to break the Black (-) wire of the fan and connect the switch
I have this switch here: http://www.radioshack.com/product.as...5Fid=275%2D701
It has no labeling on the back and I have no manual.. I'm using it to switch on / off some cooling fans..
How do wire it?
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
<puzzled> Huh? </puzzled>
Can you be more specific please?
So your saying I should run the power wires straight to the power source and then take the ground from the fans and put that to one peg of the switch and then the ground from the vehicle to the other peg of the switch?
All a switch does is break a wire, then when you switch it, it puts them back together. Get the fan running. Cut any of the wires in half. Put one end on one terminal of the switch. The other end on the other terminal of the switch. When its off the wires will be broken. When its on, it will put them together again. I suggest you buy one of those 50 in 1 science projects from radio shack that teaches you the basics of electronics. I had one when I was a kid and learned a ton.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
Yes, That will work.... for fans (low current draw) it does not matter which wire is switched.
The switch opens (off) or closes (on) the circut for the switched part. I hope that helps.
TruckinMP3
Read the FAQ!
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
If you are going to be putting a lot of voltage/amperage across that switch, i would use the switch as a toggle for a higher rated relay.
Quick! To the Popemobile!
