I don't recommend it... what happens if tempratures drop below 32 degrees... even if you live in a climate where it "never" gets that cold, weather is unpredictable...
If it freezes, the occuring ice would burst the tubing.. when it starts to melt it would drip inside your pc and either short out or even worse short out and start a small fire..
LinkBack URL
About LinkBacks
for info on thermal properties of liquids. I'm sure that there's a liquid that won't freeze and that won't screw up the pump + seals and will have good thermal properties to work in the water cooling system.
Tell us what you find.
