Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Running Raid 0?
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    Running Raid 0?
    Anyone currently running raid 0 in their carputer? I have 120 gig and my space is getting limites, so im considering getting another 120gb seagate and a raid controller. Should help the boot up times considering thats the only thing that bugs me. Plus I'll get the extra space I need.
    Jan 2003
    Ruston, LA
    It's gonna increase your boot time.
    The controller has to be initialized, and there are a lot
    of small files that need to be accessed at boot.
    Probably add 3-6 seconds to your boot time.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Newbie jarubio's Avatar
    Dec 2004
    Round Rock, TX
    You should see some increase in response time, not in boot time. The more hard drives you add, the faster the response time. The bad thing about RAID 0 is if you loose one hard drive, you loose all of your information. You may be interested more in RAID 5. RAID 5 has its draw backs, you need a minimum of three hard drives, and your total capacity will be the number of hard drives minus one hard drive. For more information on RAID, check this website out http://www.acnc.com/04_00.html
    Ford Expedition XLT 2003
    My Work Log
    Progress 40%
    Newbie JW™'s Avatar
    Nov 2004
    Valencia, CA
    Why not just add the drive and extend your existing volume (assuming you're running W2K or WXP). A RAID setup just to gain space isn't worth it; its primary benefits are stability and read/write speed for applications. frodo's dead on about boot times being increased, although I think his figures are optimistic
    (In case anyone's wondering, I'm a systems administrator, running ten W2K servers and one AIX server, all running RAID 5-E.)
    JW™
    Powered By Sarcasm
    Ranger: Just bought all my replacement goodies
    Expy: Kenwood KDC-X579 from the Ranger; unknown speakers/amp & 10" Earthquake sub, that all came with the truck
    Jan 2003
    Ruston, LA
    Quote Originally Posted by JW™
    nah, I think my figures are about right for IDE raid
    now scsi raid controllers....add 10-15 seconds
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    I would just get a nice quick HDD for your OS and GPS maps etc keeping your media on the 120gb or up that to a 20gb as well. I have 4 IDE connectors on my mobo with 2 separate controllers and the delay for the second controller drives me nuts - it's only about 4 seconds but add that onto the normal IDE drive initialisation and memory, CPU check etc etc and my PC seems to take a lifetime just to get up to the start of XP booting.
    Also turn off autodetect etc on your IDE channels. Boot time on an Athlon 3000 should be a couple of seconds. Maybe its time for a fresh xP install anyway!
    Mar 2004
    Bristol
    Oh and run the drives as normal master and slave (or master and master if you don't have an optical drive on IDE).
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    I agree with frodo about the boot time, and raid 0 does not make you loose 1 hard drive. I've ran raid 0, it stripes, does not mirror. Anyway...how the hell do you have that much music? I would consider a software based raid measure. I havent used one of these but i've heard of them being useful.
    PC Components:
    My work log
    Dec 2004
    Maryland
    Also, raid 5 requires a minium of 3 disks, raid 0 you only need two. you should read the info on the site you posted jarubio
    PC Components:
    My work log
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    don't forget
    in a raid 0 you can expect your mtbf to 1/Nth (where N is the number of drives in the array) the mtbf of a single drive running alone. i wonder what the actual mtbf for a given drive would be in a car setting?
    don't worry i know i usually don't make much sense
  1. power problems while car is running..
    By TimW in forum General Hardware Discussion
    Last Post: 03-18-2006, 09:11 PM
  2. Replies: 2
    Last Post: 12-17-2004, 01:27 PM
  3. Replies: 2
    Last Post: 07-19-2004, 12:25 PM
  4. Running Two Computers?
    By dapilot in forum Power Supplies
    Last Post: 04-15-2004, 08:14 AM
  5. Replies: 9
    Last Post: 11-01-2002, 11:21 AM
