Results 1 to 10 of 12
Thread: Basic Question: How do I get my computer to display on my Xenarc
    Dec 2004
    Hi all, I have a 7" Xenarc touchscreen installed. I have the USB and VGA ports. However, my laptop does not have a screen on it (I've taken it off). My question is a very simple one. I hook up the 7" Xenarc to my laptop but my computer will not show up on the Xenarc.
    If I hook up my working laptop with a screen I can have my desktop extended onto the Xenarc but what do I do for my car laptop which has no screen?
    I can hook it up to an external monitor and install the drivers for the Xenarc but how do I get it so that the Xenarc is used as the primary display?
    Any help is appreciated?
    Raw Wave
    Jun 2004
    On the beach
    This is probably a BIOS Setting, have a quick look around it .... some details of the laptop will help as people here can probably assist more.
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    There is often a key combination to switch between the lcd screen & the VGA out....usually a CNTRL-function key combination.
    Jul 2004
    Try Function F4.
    Raw Wave
    Jun 2004
    On the beach
    Its FN(Function)-F7 on my AJP laptop
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    FN F8 or F12 on some of the laptops i've seen, usually they clue you in by blue icons on the keys or colors matching the color on the function button
    PC Components:
    My work log
    Dec 2004
    It is an HP Pavilion laptop - N series.
    The reason I didnt think of the FN keys is because if I hook up an external 17" monitor now, the display goes to that automatically. Is it something different with touchscreens and using the FN keys? I never knew that. Its at my house so I will have to try that when I get home.
    Thanks.
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    HP's are usually FN + F5 to toggle through the different displays.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by PDiddy
    Some monitors have the capability to identify themselves when polled by the computer - they can send the model number, display settings, and other things. (I forget what it's called) The Xenarc doesn't do this, so that may be why the laptop doesn't automatically recognize it.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Make sure the your display properties are set at 60Hertz. That's the problem I had.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  1. handheld computer display
    By finnman925 in forum LCD/Display
    Last Post: 02-23-2003, 02:26 AM
  2. Getting computer display correct on 7" widescreen
    By Nicholasp27 in forum LCD/Display
    Last Post: 02-09-2003, 07:24 PM
  3. display and laptop question
    By jstrain in forum General Hardware Discussion
    Last Post: 04-04-2000, 01:05 PM
  4. display question
    Last Post: 03-24-2000, 03:48 AM
  5. LC Display Hook-up Question
    By GR1NCH in forum General Hardware Discussion
    Last Post: 02-26-2000, 10:29 AM
