Results 1 to 2 of 2
Thread: interference
    Dec 2003
    i hooked up my myfi satellite radio using a mini cable to mini cable which goes from lineout to line in. there is interference sounds like a power sond as if you were using a power inverter from you carputer. it is a horrible sound. when i use a mini to rca cable and go direct to the amp there is no noise at all. seems like the carputer is picking it up from somewhere.
    please help
    Dec 2003
    i think i figured out the problem. i am getting power from the cig lighter for the myfi. when i disconnect the power to the dock the noise goes away. so they problem is the power is dirty. i think i will try to tap into the lilliput since it goes to the opus. i tried using an mp3 + external sound card i still had the same problem.
    and a bit off topic on media engine their is no way to mute the lineout until you click on the fm-xm icon. since some other front ends have that option. So to fix that all i hit was mute in the properties of the sound card for line in and media engine automatically unmutes it when i click on fm-xm radio. so that works out awesome
  1. Weird video interference problem! HELP!
    By lookinco in forum LCD/Display
    Last Post: 03-18-2011, 07:10 PM
  2. Audio interference from my WiFi card
    By The Grinch in forum Wireless Communications
    Last Post: 09-17-2005, 03:23 PM
  3. Video Interference Problems ... Help ASAP!!!!
    By Diewlay Lowmo in forum LCD/Display
    Last Post: 08-01-2005, 12:28 AM
  4. digital voltmeter = interference??
    By owibitmytongue in forum General Hardware Discussion
    Last Post: 09-01-2004, 08:26 PM
  5. USB Cable interference
    By winkelhoch in forum LCD/Display
    Last Post: 05-19-2004, 03:29 PM
