Results 1 to 10 of 10
Thread: s video
    Variable Bitrate 84RegalRider's Avatar
    Nov 2004
    San Diego
    s video
    Can i cut up a s-video cable and reduce the length of the connector and still have it work?
    Thank
    Nov 2004
    NYC
    I wouldn't recommend it, unless you like splicing very thin wires.
    Aug 2004
    Ann Arbor, MI
    Nonsense! There are 4 wires in an S-Video cable. With a little care and touch you could easily shorten your cable just fine. Chop off a section of wire and match the colors to re-merge them. Or, get a new interconnect from your local electronics supply store and use that.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    It could cause you some interference/bad signal strength. I'd not recommend it, but your call.
    CarPC install is starting to come along again...
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    I second greyscale...don't do it!
    Kimi ga kawareba, Seikaimo kawaru!
    Jan 2005
    Edinburgh, Scotland
    I wouldn't splice if possible.
    Buy a high quality connector, cut the wire, and solder the new connector on.
    If you aren't good at soldering, get someone else to do it or give it a miss.
    May 2004
    Arkansas
    Quote Originally Posted by got2liv4him
    grAyscale
    Aug 2004
    Ann Arbor, MI
    A long as you take care to keep the individual wires the same length, you won't have issue with bad signal strength (you aren't lengthening the cable, afterall). Interference however, could be an issue as Grayscale pointed out. To combat this, simply get a shielded interconnect from Radio Shack and use that instead of the old cut off one. I would challenge anyone to find a meter-able or noticable difference in signal output this way.
    Nov 2004
    San Diego
    i will try it and if i dont like it will just throw it away.
    Thanks for your knowledge
    Aug 2004
    Ann Arbor, MI
    lol in all the technical thought, I think I've forgotten that this entire 'experiment' will cost all of $5. go for it and let us know what happens
  1. VIA onboard video overlay settings
    By Nanozic in forum General Hardware Discussion
    Last Post: 07-23-2004, 01:55 PM
  2. Custom Video Switching Device
    By mbkowns in forum General Hardware Discussion
    Last Post: 07-14-2004, 01:10 AM
  3. Media Car video player
    By MatrixPC in forum MediaCar
    Last Post: 03-22-2004, 01:33 PM
  4. Weird problems with video and ME 2.1
    By Rireal in forum Media Engine
    Last Post: 02-20-2004, 07:33 PM
  5. Divx video playback
    By mindtool in forum MediaCar
    Last Post: 12-08-2003, 06:19 PM
