Results 1 to 10 of 13
Thread: 4 inch Linear actuators
    Constant Bitrate Lando's Avatar
    Apr 2002
    Does anyone know the cheapest place to get 4 inch linear actuators. The least expensive I've foud in $109
    Aut cum scuto, aut in scuto
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Sorry, I don't but hope you get a reply. I'd like to get one myself.
    BTW: What's the $109 source?
    Want to:
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Sorry, I don't have a source for a cheap actuator either, the ones I have seen are pretty expensive. I don't know if this will help but you might be able to use a servo motor with a worm/screw drive (think thats what its called) to get similar behavior to an actuator.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Mar 2004
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Quattro-A4
    I have been looking into doing this but the problem is you need to mod the servo to allow constant revolution and a screw drive is massively geared down and a typical servo takes about 1.2s to do 360 degrees and with a thread pitch of 5mm (eg a vice screw mechanism) this would take about 40 seconds for 150mm of travel and that is using a very coarse pitch. If you used am M10 thread for example this would be about 1.5mm pitch and take 2 minutes to travel 150mm.
    I am using 150mm as it is about the distance you need to raise a screen o move it out of the dash
    Maximum Bitrate kiltjim's Avatar
    Feb 2004
    PA, USA
    I don't know where you can get a linear actuator either, but you might be able to use the servo idea, with a little improvement. You could use the servo to move a lever arm. Alter the angle to fit you needs, and the length of the arm or arms, and you might only need to move the servo an inch, to accomplish a full 5".
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    7" Lilliput TS w/DigitalWW in-dash mount
    80GB External HD
    I am Zero Bitrate....
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by ktritz
    Am I supposed to use an inverter to actuate that? It's 115 volts.
    Want to:
    Feb 2004
    PA, USA
    You know.... you never did say you were using it in the car. But yes, in order to use it in the car, you would need an inverter. Not much good I think. I'm sure looking through the surplus catalogs, you might be able to find something. But come to think of it, I don't remember ever seeing anything that was DC.
    2000 Subaru OBS
    Dell P3 @ 900 Mhz
    80GB External HD
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    How bout something like the power door lock motor? Actually it would need to be modified since it would probably not move the distance you need and would act too fast.
    Maybe you should check out BugByte's site
    http://www.dellabarba.com/ibug/Insta...stallation.htm
    You can also get up to 3/4" of throw from a regular R/C servo with this.
    http://www.bpesolutions.com/mechoduc...#anchor2236281
    http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
    Are you trying to get an LCD to rise from the dash or something?
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    A quick cheap way is to make your own... I've done it before and it works quite well...
    Get a good small hobby motor...gear reduced for even more torque... attach
    some all-thread to it... (homemade misalignment coupler even... small flexible tubing)..
    Get a small block of alum and drill and tap a hole in it to accept the all thread...
    then mount whatever linkages to the alum block to achieve whatever you want.
    For controlling distances you can use some micro switches at travel limits or such.
    I usually get my tinkering parts from Jameco.com and they have a nice selection of small dc gearhead motors...
    Hope that helps...
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  1. 8 inch Lilliput
    By Turbodude in forum LCD/Display
    Last Post: 01-13-2005, 10:17 PM
  2. 17 Inch laptop Overheating Issues
    By riuster in forum General Hardware Discussion
    Last Post: 07-14-2004, 05:27 PM
  3. 5 inch TFT
    By jameswy in forum LCD/Display
    Last Post: 03-22-2004, 04:50 PM
  4. Who knows something about linear actuators?
    By SuperMatty in forum Off Topic
    Last Post: 05-06-2003, 05:22 PM
