The CPU should be the same. It will have a smaller heatsink and heat transfer tube on it that will need a standard hs/fan. What's wrong with leaving it in the laptop case and hooking up your existing screen to it if everything else works?
I may be able to get a laptop from a family member with a broken screen for free. It is an hp ze4325us laptop. The specifications says that the processor is an AMD Athlon 2000+ 45w. Is this the same thing as the mobile athlon processors? Could I use this processor with a micro-atx board for my carputer?
EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
Rick S.
XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
exactly. then you have an onboad battery to take over in voltage drops and can do direct DC to DC convertor.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
I thought about that, but this is going in a show car so I want the install to look good. I already have an opus 150 and everything else needed for the install. All I need is a motherboard. I'm either gonna go with the Biostar motherboard or go with an ASUS board and do the pin mod. If emailed opus to see if I can RMA my power supply to get it to work with the Biostar.
