Results 1 to 10 of 10
Thread: XM Direct Audio Issue
    Oct 2004
    Milwaukee, WI
    I purchased a XM Direct, and have been trying to get it to work for a while now. I have successfully activated it, and have been using TouchXm and Xtreme PCR to view the channels. Before I had it activated (I didn't realize it had to be on), I was able to listen to Channel 1 and 247(?). Now I can't hear anything, just interferance noise.... yet I can see all of the channels.
    This is what is wierd, the noise stops when I take out the right RCA cable. Has anyone else had this issue? I have tried two different stereo RCA->stereo 1/8" jack, and still nothing.
    Perhaps I have a deffective unit.
    Low Bitrate Bigassbike's Avatar
    Oct 2004
    On the computer
    I have had the same problem. It was a grounding problem. I grounded my computer case, and it solved the noise issue. (static) As far as no music, I am not sure. I would call XM and ask them to refresh the unit. I think that would be a good place to start.
    Good luck!
    Planar 12.1TS
    Xenarc 700TS
    Xenarc MP-SC8 Mini P4 Aluminum Car PC
    Sound Blaster® Audigy® 2 NX
    2.8 Celeron D
    512 PC2700
    Dual Odyssey 1200s for Power
    Jun 2004
    OK.. slightly off topic but still a question. I just got an XM direct system (with the XM commander). I plan on building the serial interface cable to run off my car PC as is outlined in other areas. those cables all have a 12V tap, though. The instructions for the XM commander/Direct setup show using another 12V power system that plugs into the XM direct. Do I need both 12V taps or could I just use one or the other (preferably for my setup the one that goes straight to the XM direct)
    Jemmi
    Oct 2004
    On the computer
    One or the other. I have the same setup.
    Planar 12.1TS
    Xenarc 700TS
    2.8 Celeron D
    512 PC2700
    Nov 2004
    St Louis
    I have the same system, too. Was wondering if you guys still hsave your commander controllers? I need one for an project I just started.
    Jun 2004
    So If I use the 12V direct to the XM Direct then the 12V on the serial cable isn't needed... is that what you're saying for sure?
    Oct 2004
    On the computer
    Quote Originally Posted by Jemmi
    I'm runnin mine straight off the batteries with a switch. So far so good, but I'm going to be responsible if you fry yours.
    Planar 12.1TS
    Xenarc 700TS
    2.8 Celeron D
    512 PC2700
    Jun 2004
    Oh of course you wouldn't be responsible... I mean will work one way or the other I'm sure... just wasn't sure if you needed both... would find out on my own when I hooked it all up (when it warms up here)
    Oct 2004
    Milwaukee, WI
    How does this work with resume from hibernate?
    I get sound now from all channels, but the static from the unit is terrible. I have the unit mounted right next to my opus, so I could plug in the the +12V or the ACC. I would assume that I should use the +12V, but wouldn't that leave the XMdirect on all the time? How would this affect Frodoplayer?
    Thx
    Jan 2003
    Ruston, LA
    Quote Originally Posted by beckkl
    It wouldn't.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. XM Equipment CHEAP! XM Direct $29!!!!
    By hevnsnt in forum General Hardware Discussion
    Last Post: 04-11-2006, 10:18 PM
  2. XM Direct Audio Quality
    By EBJUSTIN in forum General Hardware Discussion
    Last Post: 12-03-2004, 12:08 PM
  3. XM commander for same $ as direct?
    By ACHIEVER in forum General MP3Car Discussion
    Last Post: 11-20-2004, 09:43 PM
  4. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  5. Replies: 5
    Last Post: 02-29-2004, 08:18 PM
