Results 1 to 10 of 18
Thread: Beware of EPIA M 1.16 BIOS
    Constant Bitrate ZenerDiode's Avatar
    Nov 2003
    Bay Area
    It's the Devil!
    Mutha - F*****
    First, it's putting out some funky refresh rate that screws up the lilliput and makes it go over range...
    Now, i can't even get a VGA out.
    I should have read up on this ****ty *** BIOS but how could I have possibly known?
    So just a warning to anybody that wants to flash the bios to get widescreen resolution capabilities....BEWARE!
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Sticky this
    Nov 2003
    Bay Area
    Yeah, there are only a couple of threads here about the 1.16 Bios...but over at via-arena...there are quite a few people *****ing about loss of VGA.
    Jul 2004
    Did you install the new video drivers after you flashed? Each time via updates the bios you need to have the latest driver version installed. I had the same problem when I flashed from 1.07 (or was it 1.06 don't remember the number exactly) to 1.13. installing the new drivers fixed the problem. Also make sure your bios is set to CRT not and not LCD.
    Hope that fixes it for you.
    -momanz
    The key sequence to get you to the video section of the bios is...
    when you boot hit del several times
    then...
    down arrow
    down arrow
    enter
    down arrow
    down arrow
    pgup and pg down will toggle through the choices. Or you can try clearing the cmos (check your manual for the procedure).
    Constant Bitrate cbergeron's Avatar
    I just upgrade my Via's bios this past weekend to 1.16. I didn't have any issues though. Perhaps it's how your BIOS is configured BEFORE flashing?
    I'm happy because my Epia boots a couple of seconds faster with 1.16 than it did with 1.03b.
    My Epia is pretty old tho and it's what I'm using in my daily car.
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    Nov 2003
    Bay Area
    Just FYI
    the via-arena thread...one of the resolution seems to swapping RAM as there seems to be some memory-timing issues with the BIOS. I'm flashing back to 1.09 personally...
    http://forums.viaarena.com/messagevi...VIEWTMP=Linear
    BTW, it isn't the VGA drivers...I made sure to install the latest drivers as posted by VIA.
    Jun 2004
    The North, Manchester
    least yours working - i bought GB of RAM for mine and it wouldnt boot up with it - swapped it with the 512 in my desktop and now it works fine.
    Via-Arena was very helpfull - apparently if your video is set to LCD before you flash this causes problems
    Nick
    Constant Bitrate superbowl's Avatar
    Jan 2005
    Germany
    Hi,
    i bought a new M10000 a few weeks ago (my 5000 was much to slow) and my new board came with 1.16 installed.
    It works 100% perfect !
    Maybe the problem is the process of flashing, but the bios ist working very fine.
    - stefan
    Oct 2004
    Netherlands
    hi i had the same with the bios, try taking out the battery for 30 sec it will boot up again with vga output (swapping ram had no effect with me tried 5 different types) but if i now put my bios in LCD mode it has no vga output, when i switch from 32 mb shared to 64 it has no vga out either
    my destinator map resource down permanently
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    If you do not get a picture on your Lilliput/Xenarc, just connect it to multisync CRT monitor (you should be able to see the VGA picture as usually), enter BIOS and change "Select display device" item to >>CRT<< in Advanced chipset options menu. Save by pressing F10 and reboot. From then, you will be able to use your Lilliput/Xenarc as before. Just remember it will default to "LCD" again if you reset your CMOS.
  1. BEWARE: Epia V8000 & Opus 90W combination
    By Jailer in forum General Hardware Discussion
    Last Post: 12-28-2004, 08:57 AM
  2. epia m-9000 bios update problem
    By saletel in forum General Hardware Discussion
    Last Post: 12-12-2004, 07:27 PM
  3. Updated Epia M BIOS to I0100116.bin
    By EBJUSTIN in forum General Hardware Discussion
    Last Post: 11-13-2004, 12:35 AM
  4. Epia Bios
    By Navigator_82 in forum Newbie
    Last Post: 03-25-2004, 04:17 PM
  5. What bios options for fast boot on EPIA M-1000
    By ugosplat in forum General Hardware Discussion
    Last Post: 08-13-2003, 09:42 PM
