Page 22 of 40 FirstFirst ... 121314151617181920212223242526272829303132 ... LastLast
Results 211 to 220 of 392
Thread: Commell LV-671..
  1. #211
    Jan 2004
    Austin, TX
    Quote Originally Posted by Giuliano
    Thanks to Eric, today I received a few very important pieces of information:
    1. The specification sheet for the DC_IN power jack on the rear of the board (DC_JACK.PDF).
    2. The specification sheet for the W83601R SMBUS GPIO chipset, which we already had.
    3. A segment of sample code for reading/writing the I2C bus - appears to be C code, possibly for DOS. (I2C_Sample.txt)
    4. The Intel BIOS Modification Program (BMP)
    #4 is a VERY IMPORTANT bit of news, and here's why:
    The Intel Video BIOS for the on-board Intel Extreme 2 Graphics is intended to be able to be modified by OEMs without the need for the source code.
    What this really means:
    Can the BMP remove the 80pin conductor error message for the secondary ide port?
  2. #212
    the P1900 power supply is out now!!! How does this PSU monitor if our boards are on or off?
  3. #213
    Nov 2003
    Marietta, GA
    When jumpered for "Standby" the P1900 monitors the current being drawn by the CarPC system. If it exceeds approximately 1 amps during Standby, the P1900 will go into Forced Shutdown mode.
    MikeH
  4. #214
    Quote Originally Posted by MikeH
    It would be ideal (but I don't know how it would be done) if there could be a way for it to put the computer into Hibernation from Standby when the battery is about to reach the low voltage cutoff.
  5. #215
    Nov 2003
    Marietta, GA
    Hmmm... is this possible?
    MikeH
  6. #216
    The only way I would see it working is if (when in standby) the computer could get a signal (serial port?) telling it to Hibernate. That is if you can receive signals from the serial port while in standby. You can set a laptop to hibernate when the battery reaches a certain %, and it'll do it even when in Standby. But I'm sure the laptop has something built into its motherboard monitoring the battery levels.
    Right now I just have my computer set to Hibernate after being in Standby for 5 mins. Although I have to pause music or video playback to put it in an "idle" state.
  7. #217
    The land of polar bears and nekkid blonds
    It looks like Commell is returning my board that I sent back because of my problems with different soundcards.
    Apparently the south bridge was "bad", despite my efforts to try and get some more information
    as to what actually was "bad" and how that could have happened, that's all the info I got.
    Heck, I didn't even think it was possible to change the southbridge, so it should be interesting
    to see if there will be any other changes too it. The service information also said "BIOS update",
    but I allready had the latest so that's also going to be interesting.
    Hopefully I'll have it back by the weekend, I'll keep you all posted.
    /M
  8. #218
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    http://www.gnetcanada.com/vehiclepc-overview.htm
    have you guys seen this? they might be headed somewhere with this.... hmmmmmm
    if they only have an option for more storage and some better power options (standby, hibernate) then this might be a pretty good all-in-one system for those who dont wanna do it themselves (just wanted to see what you guys thought of this)
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  9. #219
    Maximum Bitrate MobiTekLink's Avatar
    Jun 2005
    Queens, NYC
    Quote Originally Posted by kmccann1
    I purchased the LV-671MA and the MA-ATI. I haven't done much work on it lately though and i haven't done anything with the LTM09C362F display I bought either. I had contacted you about making an LVDS cable for me, as I doubt i have the skill or patience to work with something that small. I'd be willing to send you the display and card if needed to sort it all out. Send me a PM or an email..
    One other question though: How do you get rid of the annoying '80 pin cable not connected to secondary IDE' message or whatever it says? I am using a laptop drive and a 10" 44pin cable and that message adds considerable time to my bootup.
    On another note, the Swiftech AMD heatsink works wonders.
    I don't know if you fixed that issue with the 80pin cable or not, but I found that in the bios on the first entry (under standard settings)you can just ignore errors and it'll skip right through it.
    08 Lincoln Navigator www.mobiteklink.com
  10. #220
    Jun 2005
    Queens, NYC
    Power off/on issues
    Hey guys,
    I have a lv-671 CelM 1.4, with a cnx-1900 psu. I'm having issues with it using the acpi function. I did the relay just like in the diagram avail here but no luck!!
    I was wondering if anyone had issues with this setup or if there might be some bios issues.
    I can't think of anything else, and I don't want to mess it up.
  1. Commell LV-671 for sale soon
    By ddogg_777 in forum Classified Archive
    Last Post: 10-28-2005, 02:37 AM
  2. Anyone using Commell LV-670 P4 mini ITX?
    By Ricky327 in forum General Hardware Discussion
    Last Post: 05-14-2004, 12:55 AM
  3. Anyone heard about Commell LE-362? (nano-ITX sized MOBO)
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 05-14-2004, 12:22 AM
  4. Commell LV-671 for $267 each, USA only
    Last Post: 04-24-2004, 11:15 PM
  5. Commell P4 Mini-ITX mobo
    By lemming in forum General Hardware Discussion
    Last Post: 01-31-2004, 05:56 AM
