Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
Thread: Compact IR Reciever
  1. #31
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by antimatter
    So to fix the USB resume from hibernation problem i used devcon.exe to disable/enable the usb device in a batch file triggered by my front end frodoplayer (has a "run on resume" command)
    However this one didn't work with my Remote. It detected different codes for the same button. If i held the button down long enough it would detect different codes randomly. It did work with every other remote i tried.
    Does the plugin has something called "Device priority"? The Igor serial plugin has that setting. I have this problem before. Change the priority to higher. The default is 7, and I change to 8 which work perfect.
    You may want to try different remote to see if it capture the same code everytime (without changing priority).
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #32
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by MatrixPC
    unfortunatly it appears to be the remote because all the other remotes i have tried (except the friggen one i want to use) works
  3. #33
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    dont feel bad, the remote I wanted to use sent out too many codes as well. I am waiting for a steering wheel remote to come along to try.
    肚子笑痛了
    S60 Install
  4. #34
    Sep 2003
    Beach City, Socal
    One of my Alpine remote spit out 3 or 4 different codes for each button. After play withit for a while, I figure out that some has 4 codes and some has 3 event 2 codes.What I did is capture all codes for that button and put it in 1 actions.
    Example
    Action = Volum up
    EventString: Code1A, Code2A, Code3A, Code4A
    Action = Volum down
    EventString: Code1B, code2B
    You get the idea.
    Unless each button sent out more than 1 code and they cross match with other buttons, then that remote is useless.
  5. #35
    Jan 2004
    California
    Example
    Action = Volum up
    Action = Volum down
    You get the idea.
    Unfortunatly the buttons do crossmatch. Someone PM'd me to try the MCE plugin for girder. I need to research that. I don't even know if it will work with my reciever.
    the crappy part is the remote that i have is so slim (1/4") And it was made to control a your computer. I wonder if i get the receiver (since all i bought was remote) that it was meant to have if i can get it to work With the MCE Plugin.
  6. #36
    Jul 2002
    Boston, MA
    I know this is old, but here's a USB version...
    -Mario
    http://www.geeks.com/details.asp?invtid=USBTOIRDA-NB
  7. #37
    Jan 2004
    California
    Okay, thats great except for the fact that it wont even work.
    Thats IRDA. You can't use your remotes and girder with that.
  8. #38
    Jul 2002
    Boston, MA
    Okay, my bad...
    -Mario
  9. #39
    Jan 2004
    California
    thanks for the thought though
  10. #40
    Variable Bitrate rubicon's Avatar
    Feb 2005
    $240 worth of puddin'
    Quote Originally Posted by judoGTI
    Dont the homemade ones eat up CPU cycles?
    Well, its not that homebrewed hardware is less efficient - its that the software might be polling the serial port for data, instead of responding to an interrupt. It's a hardware agnostic kinda thing.
    Put it this way - which would take more work?:
    a) checking every x minutes to see if a package you ordered has come, or
    b) putting a sign up outside that says, "UPS guy - please ring bell"
    Scenario 'a' would, of course - and that's what you're doing when you poll. Scenario 'b' is akin to an interrupt.
  1. Which IR reciever for ME?
    By Glyn in forum ME Archive
    Last Post: 12-29-2003, 09:29 AM
  2. Settings for Mastero's IR reciever
    By backpack09 in forum Input Devices
    Last Post: 07-29-2003, 11:45 PM
  3. Another IR Remote Reciever?
    By timothy in forum General Hardware Discussion
    Last Post: 12-26-2002, 07:38 PM
  4. IR Reciever
    By GMJArts in forum General Hardware Discussion
    Last Post: 08-24-2001, 01:45 AM
  5. IR reciever
    By edie209 in forum General Hardware Discussion
    Last Post: 11-28-2000, 03:03 PM
