There seems to be a problem with the motherboard, sometimes i'ts loosing the comports, secondary ide channel, floppy disk drive and parallel port.
When chekking in the bios settings menu point "PC HEALTH STATUS", the cpu temparature and the voltages is totally screwed up.
CPU temp = 174 degrees ( the cpu when measured with external meter, 29 degrees)
3,3 V = 4,417 ( Measured directly on psu 3,33 V)
5,0 V = 6,576 ( Measured directly on psu 5,12 V)
12,0 V = 14,993 ( Measured directly on psu 12,1 V)
When the board boots up ok, the different voltages show up perfectly in the menu point.
I've also tried to put a different memory stick on to it, but the same result.
I haveand found some other posts, but not yet an solution. Has anybody else had this problem.
Please help, as this system was supposed to go in the car saturday.
There's somthing rotten in the state of Denmark.
Finished IIIIIIIIIIIIIIIIIIIII 99,5%
M10000, 256mb, 20gb 2,5" drive, 7" vga touchscreen.
