Results 1 to 10 of 19
Thread: computer into wood enclosure
    Variable Bitrate nsmoller's Avatar
    Dec 2004
    NY
    i am making a fake floor type setup in my 4runner, it will be a carpeted (on the outside) wood enclosure
    i bought a case for 30 bucks and its too big (for my desires). i have a matx form factor and was wondering can i just screw the mobo into the wood enclosure (using the standoffs of course)
    someone mentioned something about grounding the circuits? i guess that means mobo and PS? how do i do that?
    fire? is that a concern?
    [4Runna]
    next - wifi
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you could jsut screw standoffs into the wood but most mobos are earthed through the metal around the holes intot he case so you just need to have all these points linked and earthed. Might be easier to get an old back panel off a case (the bit the mobo bolts to) and screw this down 1st. If you hack up a case you can get the pci card supporting bit too.
    EDIT: jsut gonna make myself a bit clearer:
    If you have an old case with the side the mobo and the back face were all the cards bolt to and the back conencters come through just cut this (carefully as the thins steel is sharp) and bolt this down. This way you get the nice earthing (make sure the case section is then earthed to a common point along with other parts of your system) and you get good support for any PCI cards - if you have any. Loose PCI cards will cause you a lot of trouble with hanging and crashing. YOu might also want to brace the L shape as if it flexes even slightly then the cards will twist out. Thats why cheap cases are crap and cause loads of trouble.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Use standard standoffs you should be fine.... wood is actually great to use because it doesnt conduct electricity !
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    Quote Originally Posted by Scouse Monkey
    This is interesting, i heard that the mobo is grounded via the psu connection
    Constant Bitrate vintageb3's Avatar
    Nov 2004
    Scotland
    Quote Originally Posted by IntellaWorks
    It does if it's wet
    vintageb3
    M10000 mainboard,256 RAM, 80 Gig 3.5" drive, PWS-120-M, ITPS, Lilliput 7" touchscreen, XP Pro SP2, Frodoplayer, Map Monkey, InfoMap Navigator 4, WIFI
    Current: Bluetooth. Trying to get Phonecontrol to work with SE T610.
    Mar 2004
    Bristol
    Quote Originally Posted by scott_fx
    well yeah it is for the current flow but the PSU is also metal (and therefore must be earthed due to regulations) and bolted to the metal frame to which the mobo is bolted too using metal standoffs with metal rings on the board where the screws go. Some mobos have fibre washers and plastic screws but i have never used one of them. I was concerned about the direct electrical connection to the case when i built my 1st PC but i guess it makes sense to have it earthed.
    Nov 2004
    Scotland
    Quote Originally Posted by nsmoller
    I don't have an enclosure...I hauled out my glovebox compartment...and made a new glovebox lid from MDF...the mobo and the ITPS are mounted onto standoffs...I have no problems in that area....
    "What's that burning smell dear?"
    vintageb3
    Mar 2004
    Bristol
    Yeah i was jsut gonna add, try it with no earthing, just using the wood as it will be easy and see how it goes. If you get any problems try earthing it. I would still make provision for decent PCI card support though.
    Nov 2004
    Scotland
    I don't know if this is correct or not...but my mobo isn't grounded...well at least not at the standoffs...I assumed it should be isolated....but i have been wroing before....
    It was a Sunday evening in 1977...
    vintageb3
    Mar 2004
    Bristol
    Quote Originally Posted by vintageb3
    vintageb3
    Yeah it could be, i have seen some isolted ones but never built one. The metal rings ont he mobo might not link to anything and might just be there to protect the GRP board from damage fromt he heads of the screws. At the end of the day if your mobo is normally bolted to the case using metal screws and standoffs then it isnt going to do any harm bolting it to metal again. But if it isolated then keep it so. I always assumed the earthing was to protect the board from static. Like the way i always have a PSU plugged into the mains at hand when working with electrical stuff to earth myself.
  1. Fiberglass Sub Enclosure project
    By shillier in forum Fabrication
    Last Post: 02-06-2009, 03:30 PM
  2. 400$ computer
    By Slitha in forum General Hardware Discussion
    Last Post: 05-09-2005, 08:38 PM
  3. computer to computer network help
    By nappyjim in forum Wireless Communications
    Last Post: 10-31-2004, 08:49 PM
  4. sound computer connection...ive tried everything.
    By supralightning in forum General Hardware Discussion
    Last Post: 09-14-2003, 07:21 PM
  5. computer diagnostics for 4runner
    By Dluvr22 in forum Off Topic
    Last Post: 08-13-2003, 09:59 PM
