Results 1 to 9 of 9
Thread: another disappointment - motherboard
    Variable Bitrate warnockm's Avatar
    Jun 2004
    Virginia
    I got a Via EPIA M10000 for xmas. i used it a few times and today i went to power it on and nothing happens. I'm using an AC powersupply, not my opus with no luck. When i flip the powerswitch on the power supply off the fan turns for a second like normal, but it won't turn on at all.
    does anyone have any suggestions?
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Does the PSU work on another system?
    Jun 2004
    Virginia
    Yes, neither my Opus, nor my wired powersupply turn the Via on.
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    I had that before on a normal system, if the board is in a case then just try to take it out power it up. Also make shure nothing is pluged into it like usb devices, pci card. Good luck.
    Jun 2004
    Virginia
    thanks, already ahead of you, i unplugged everything except monitor, mouse and keyboard. I took it out of the case and everyting but to no avail. thanks for hte suggestion.
    Jan 2004
    hmmmm, ,maybe see if u can ground it... (in the case??)
    AT mobo
    Intel Pentium MMX 233mhz
    ESS Solo PCI soundcard
    Linksys NIC
    Irman
    Dec 2004
    Staten Island, NY
    in a situation like this i would also recomend 1) goto sleep and things hopefully be better in the morning. 2) take the cpu out and put it back in[which you can't do] 3) file for an rma from where your parents got it and exchange it.
    Variable Bitrate lawrence's Avatar
    Oct 2003
    carol stream illinois
    try to reinsert memory or try known good memory
    Jun 2004
    Virginia
    I figured out the problem. Turns out i'm an idiot. Yeah, that's the problem
    I was connecting the wrong pins for the power on switch. THe manual and wiring diagrams are there for a reason
    thanks all
  1. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 04:38 PM
  2. Motherboard Vibrating, will it be damaged??
    By syclone477 in forum Newbie
    Last Post: 05-01-2004, 11:28 PM
  3. WT: Celeron Setup for Slot A motherboard
    By EBoundEE in forum Classified Archive
    Last Post: 04-28-2004, 03:06 PM
  4. Wi-Fi Ehternet PCI Card - Is my motherboard PCI Local BUS 2.1 Compliant?
    By smoldyr in forum General Hardware Discussion
    Last Post: 11-14-2002, 07:56 PM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 05:27 PM
