Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Anyone else having any issues with Cold weather?
  1. #21
    Low Bitrate bd3521's Avatar
    Jan 2004
    Here is some possible solutions.
    1. Keep carputer under a seat so it can be climate controlled (at least during the winter) in your ride
    2. Get a Remote Starter for you car. Preheat your car 10 minutes or so before turning carputer on.
    3. Hookup a switch so you manually turn on your when you feel the interior temp has risen. (they also got those wireless temperature things you could hookup to ur case)
    4a. Make yourself a usb/firewire enclosure and take it out after cold days.
    4b. Get one of those slid out hard drive trays you can easily remove
    Good luck.
    carputer: in progress
    Laptop install
  2. #22
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    i keep a hair dryer in my trunk for the cold days... boots up fine after a minute of heating...but otherwise if its too cold, it will keep crashing after post until it gets warm enough. btw my computer is in the trunk so there's no other feasable way of heating it. and i can't get a removable hard drive cases because....well.. i'd have to build a new computer case and thats not possible while at school.
    the next install is going behind the dash so i can heat and cool it without too much of a problem
    rebuilding carpc... kinda..
  1. Opus Cold Weather Resolution
    By KaiTech in forum Power Supplies
    Last Post: 01-24-2005, 03:16 PM
  2. Liliput in cold weather?
    By Lucky13 in forum LCD/Display
    Last Post: 12-25-2004, 04:15 PM
  3. Cold weather +LCD
    By Adragontattoo in forum LCD/Display
    Last Post: 10-13-2004, 11:25 AM
  4. carputers and cold weather?!
    By mrzigzag in forum General Hardware Discussion
    Last Post: 08-06-2003, 02:00 AM
  5. Hard Drive screwed in cold weather!?!!?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-23-2000, 12:41 PM
