Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Anyone else having any issues with Cold weather?
    Nov 2004
    It seems that my carputer, doesn't want to come on in the mornings, when it has been around 20 degrees Farenheit. I go to boot it up and it will begin to boot, but I never get any video. I then usually will let it run a few minutes, then I reboot it and the video will work fine.
    I am using an ATI (Built by ATI) Radeon 9200 Video card wtih 128mb Memory on the board. I have not yet had the time to figure out where the problem actually is. Just wondering if anyone else has run into any problems with the cold weather. I know we aren't that cold here compared to people in the northern US.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    The problem is your lcd. The liquid crystals can freeze and won't be able to display anything. After awhile when things warm up a bit, everything will be fine.
    The first couple days that temps here in Philly were below 20 F, my computer booted but I would get no video. Funny thing though - I think eventually that the lcd gets used to the cold, because this morning when I started the car, it was 1 degree F and the display was working, although reluctantly as it was very dim for a few minutes.
    Nov 2004
    I have noticed it being Dim at first. It does show No VGA Signal, when it first comes on.
    Would this be the same issue you are mentioning with the Crystals?
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
    Low Bitrate andyhardy's Avatar
    Mar 2004
    Bexhill, East Sussex, England
    It sounds like your hard-drive is getting too cold to start moving.
    Does your drive have fluid dynamic bearings?
    Andy
    Nov 2004
    Here is the Model: http://www.seagate.com/cda/products/...81,579,00.html
    Here is the Spec Sheet on it: http://www.seagate.com/support/disc/...t3120022a.html
    Didn't think about that, but the Seagate is Fluid Filled, not sure what type of fluid but it does state that.
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
    Low Bitrate bd3521's Avatar
    Jan 2004
    NJ
    Check out that PDF for the Seagate you listed above...
    Operating Temperature -> 32 to 140 F
    Non-operating Temp -> -40 to 158 F
    carputer: in progress
    Laptop install
    Maximum Bitrate cadence117's Avatar
    Feb 2004
    Charlotte, NC
    is that cold damaging to the lcd
    ... It seems like its getting a good bit dimmer latlely
    mobo $130 ; 150wOpus-$200 ; 256mb pc2700 -$10 ; 120gb HDD 7200-$70 ; Lilliput TS 7"-$265 ; USB LAN-Free AR ; Rikaline 6010 GPS-$34 ; ShuttleXpress-$37
    Total = $746....Carputer = Priceless
    Variable Bitrate FyreDaug's Avatar
    Jan 2005
    Saskatoon, SK
    My hard drive just doesnt detect. It can be -30 in my garage and I never have video problems, just the hdd is frozen me thinks
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    HDs do not freeze, the bearing lubricant's viscocity increases with lower temps. This causes the drive to spin slower. If the RPM is low enough the drive will not detect.
    Freezing is the point at which a liquid becomes a solid. This is not happening to your drive. LCDs are also subject to 'slowing' until they warm up.
    TruckinMP3
    Read the FAQ!
    Jan 2005
    Saskatoon, SK
    Well yes I know that, but instead of that 6 sentance description of it I figured "freezing" was good enough.
  1. Opus Cold Weather Resolution
    By KaiTech in forum Power Supplies
    Last Post: 01-24-2005, 03:16 PM
  2. Liliput in cold weather?
    By Lucky13 in forum LCD/Display
    Last Post: 12-25-2004, 04:15 PM
  3. Cold weather +LCD
    By Adragontattoo in forum LCD/Display
    Last Post: 10-13-2004, 11:25 AM
  4. carputers and cold weather?!
    By mrzigzag in forum General Hardware Discussion
    Last Post: 08-06-2003, 02:00 AM
  5. Hard Drive screwed in cold weather!?!!?
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-23-2000, 12:41 PM
