Is there such as thing as a Docking Station / Port Replicator extender? I had my IBM X20 in the docking station, but had to remove it. When I tried to remove it, it didn't move so realising it was stuck I had to push those black plastic clips back, unfortunately the actual pc case broke in the process and now the laptop never sits right on the port replicator.(Need to apply pressure on one side at just the right angle to get the usb ports active and all the colours on the screen!)
SO I thought if I could somehow get a cable to clip into the port replicator, then into the bottom of the laptop I would solve my problem. Or replace the laptop case which is going to be messy, that's if I can even find one...
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353 DiNovo Mini Car2PC ODBII
