Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: New XMD1000 Not Working!
  1. #11
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    did you edit the ini for frodo's program to reflect your comm port? and did you have XM send a refresh to your unit?
    肚子笑痛了
    S60 Install
  2. #12
    Maximum Bitrate nFiniteTuning's Avatar
    Albuquerque, New Mexico, United States
    Ok, I told XM to activate my unit today...and nothing happend for 40 minutes...so I opened eXeM and some of the channels opened up....but for some reason on eXeM, I can't hear anything.
    So I go back to MMC, and some of the channels load, and then stop, and I can only play channel 001. But it shuts off after a minute or so..whats goin on? It hasn't been 2 hours yet...should I just leave mmc running? I got all the channels to pop up on the XMConfig program.
    Everytime I reopen mmc or eXeM, a different ammount of channels load. So sometimes it could end at 40, sometimes it could end at 247, or sometimes it will end at 20. its all various. and I can't listen to the other channels. Only 001. Should I refresh?
    -Josh
    1997 Mitsubishi Eclipse GSX
    My URL: https://www.facebook.com/jagray85
    XBOX: DarkerStars
  3. #13
    Ok...I just loaded eXeM and instantly selected a diff channel...and for some reason my line in keeps muting. But I got that channel playing....but I can't change the channel.
    HAHA, while typing this message, the music stoped playing.
    -Josh
    XBOX: DarkerStars
  4. #14
    Ok, now my computer doesn't see my XMD...WTF is going on?
    It was working somewhat....but I started hearing these sounds like the unit was turning off.....and then I tried opening it up in MMC and it told me no radio hardware found. So I ran the debug program and it doesn't get any recieve signals. only send.
    -Josh
    XBOX: DarkerStars
  5. #15
    Allright, I have the XMD on my dads pc...and eXeM doesn't work right....but I ran the frodo xmdebug program on that pc...and found out you can listen to music that way....its working.....All channels poped up, I'm changing channels, listning to music...so Whats wrong with the software?
  6. #16
    Jan 2003
    Ruston, LA
    eXem currently has a memory leak.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #17
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    hmmmm..... we will check into it... must be machine specific, works fine on ours, I will contact him and we will look into it
    But I have noticed a Memory leak after about 10hrs of play that could be contributing to it...(most likely)
  8. #18
    Well...I can listen to all channels through the FrodoPlayer XMDebug program ONLY if I open eXeM first...I guess the XMDebug program doesn't send out a code or something for the XMD to put out sound....but after eXeM or MMC fails to load channels, I close it and run the debug program and I can continuously change channels, listen to music. Everything works just fine.
    I found out why my pc isn't working, the connection on the cable you sent me is sensitive...so I had to screw it on. So now my connection rocks....but only if I run the XMDebug program to change channels.
    -Josh
    XBOX: DarkerStars
  9. #19
    Jan 2003
    Ruston, LA
    The XMDebug program has a bug too
    Now go try the new FrodoSatelliteRadioX prog since the cable issue is sorted.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #20
    FrodoSateliteRadioX works great!
    -Josh
    XBOX: DarkerStars
  1. tv out on via not working anymore?
    By djmickyg in forum General Hardware Discussion
    Last Post: 06-27-2006, 04:02 AM
  2. Anyone Destinator working in Centrafuse ?
    By superbowl in forum Centrafuse
    Last Post: 02-05-2005, 11:30 AM
  3. XMD1000 locks up my carputer.
    By R32 JUhl in forum General Hardware Discussion
    Last Post: 01-25-2005, 09:41 PM
  4. Via Epia M-900 Video Drivers Not working
    By mattdisaster in forum General Hardware Discussion
    Last Post: 01-06-2005, 10:33 AM
  5. motorized screen stopped working :(
    By corsamel in forum LCD/Display
    Last Post: 11-26-2002, 10:52 AM
