Results 1 to 10 of 14
Thread: AMD Semprom 1000hz???
    Low Bitrate Mush's Avatar
    Dec 2004
    UK
    Hi
    I recently built my first pc using an AMD cpu, Everything seems to be running fine but in the bios it states that the cpu speed is 1000hz. the cpu model is amd 2500+
    So is the cpu running at its full speed or not???
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Semptron 2500+ is supposed to run at 1.750GHz.
    Dec 2003
    Germany
    a) Get WCPUID and check if the CPU is running at full speed
    b) install the latest BIOS update
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Sep 2003
    Austin, TX
    Sounds like somebody has their FSB set wrong.
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    that thing's a beast! well if you've got XP loaded on it, it's running faster than 1000 hz, but ya that's weird... ya i'm not very helpful.
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    front side bus or in bios. Get into bios and change it to default settings.
    Dec 2004
    UK
    tHANKS FOR THE QUICK REPLYS
    By the way has anyone else had any problems similar to this .
    thanks
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    Quote Originally Posted by Pudge
    i'm pretty sure xp runs on less
    Kimi ga kawareba, Seikaimo kawaru!
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    yea, XP will go on anything 233mhz and up...been there done that.
    as far as the sempron goes, they run at 200mhz, crank up the bios settings or throw some jumpers. i just went thru thaton my 2400+
    2005 Ford Focus ST
    Newbie Creoden's Avatar
    Jul 2004
    Ontario, Canada
    Quote Originally Posted by gospeed.racer
    It seams we have 2 diferent threads going on in one, we have the sarcastic/funny, and then the straight... the reason I say this is that both quotes above are correct.
    Mush states that his CPU speed is registering as 1000Hz which would be 100MHz, now Pudge seams to be playin along with the fact that he screwed up and put Hz instead of MHz, and gospeed.racer os going on the fact that yes he did mess up and put Hz instead of MHz, and possibly thinks that everyone is going along with that... anywho that ends my rant.
    but on topic, if its showing 1000MHz you must have a clockspeed/FSB multiplyer setting wrong.
    Creoden
  1. AMD or INTEL?
    By BoyNextDoor in forum General Hardware Discussion
    Last Post: 02-14-2005, 11:42 PM
  2. Asus Micro Mobo and AMD XP-M 45W Barton
    By MatrixPC in forum General Hardware Discussion
    Last Post: 01-05-2005, 06:26 PM
  3. AMD 2200+ running hot
    By DriverDan in forum General Hardware Discussion
    Last Post: 09-25-2004, 10:12 PM
  4. Micro ATX / Mini ITX (AMD, Intel, VIA)
    By wanjer in forum Newbie
    Last Post: 09-11-2004, 08:31 AM
  5. Fs: Amd Motherboards!!!!
    By TheNoodPoopler in forum Classified Archive
    Last Post: 07-29-2004, 01:03 AM
