Results 1 to 10 of 13
Thread: Camera Black Box
    Raw Wave lostreception's Avatar
    NY
    Camera Black Box
    In addition to reverse i want to make turn signals trigger camera inputs
    As xenarcs will automatically switch to the composite when a signal is detected i was thinking of making a hardware only black box to accomplish this. only thing is im not sure if it would work ive got most of it planned out only thing i cant figure out is how to make all 3 leads selectable so that the video signal doesnt bottle neck
    heres a diagram of what im trying to do ...
    eg a dumbed down version of this
    http://www.radioshack.com/product.as...Fid=15%2D1988#
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    NY
    Almost as if something like this existed
    but would it function the way i want it to?
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Maybe if you just used cable splitters to get all the cameras into the same input, but have relays so that the individual cameras are only turned on when signalling or backing up. This way only one signal is active at one time. Just can't back up and signal at the same time.
    Or you could just get a 3-port video switcher. They're pretty common. And cheap.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    May 2004
    Alameda, CA
    BTW, are the turn cameras going to be directed to the left/right at a 90deg angle from the front, for seeing around corners, or down the sides, as for merging?
    NY
    Quote Originally Posted by VanMan69
    Yea i didnt even think about that no more backward doughnuts in the parking lot I guess
    most of the Auto switchers are all $50+
    i was hoping to have something ran all on 12v
    the cheap ones require button presses to activate the different sources
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    NY
    pointed out of the boat vent diagonally to look to the blind spots heres a pic.
    im also thinking of adding a motorized sideview mirror motor to the camera housing as suggested on one of the post here and have the cam angled out the ducts
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    May 2004
    Alameda, CA
    Very nice. Those ducts are pretty slick.
    Yeah, once I get around to my rearview camera, I'd like to place it on a sideview motor, like in a little dome or window on the spare tire cover.
    May 2004
    Alameda, CA
    Quote Originally Posted by lostreception
    If you can get more detailed specs on the stuff, you can probably find one that runs on 12V, but just uses a wall wart. A lot of low-power-consumption accessories run on 12V DC (and of course 4.5V, and 9V, but you can find 12V).
    And I'm thinking that if you have all the cameras going to the same input on the screen, and you have the cameras activated by the turn/reverse signal, there should only be one camera/signal turned on at any given time and therefore no bottleneck.
    Also keep in mind: Do you want your display to switch EVERY time you signal a turn? I personally wouldn't. This seems like a freeway or tight quarters application. Maybe you could rig a little switch on the steering wheel or column or something.
    P.S. You signal when you do your reverse donuts? How considerate.
    Jan 2005
    South Texas
    Thats a great idea ! but what about when you need to use your hazzard lights? will it display the left and right camera back and forth?
    NY
    Quote Originally Posted by cet99
    im thinking it would display the stronger signal or just scramble them im about to check something i have a radio shack splitter/combiner with selector keys im gonna see waht happend if i select 2 inputs at once
    i dont belive it will be viewable just a garbled mess of video waves
    i will keep u posted
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
  1. FS: New in Box 7'' Black Lilli VGA Touchscreen
    By wonderworm in forum Classified Archive
    Last Post: 01-09-2005, 08:07 PM
  2. FS: New in BOX All Black 7'' Lilliput VGA Touchscreen
    Last Post: 11-13-2004, 12:58 AM
  3. FS: New in Box 7'' Touchscreen LIlliput, Black
    Last Post: 10-16-2004, 05:10 PM
  4. For Sale, 1 x Wireless Miniature Security Camera.
    By buildfromscratc in forum Classified Archive
    Last Post: 07-15-2004, 07:13 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
