Results 1 to 5 of 5
Thread: Anyone using Timetrax + Sirius solution
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Anyone using the Timetrax Sirius solution? I'm on to something here and need to get some info.
    Jan 2005
    MA, USA
    I'm pretty sure it's not available yet. The site let's you pre-order.. says they will be in stock "soon".
    Mar 2004
    Greenacres, WA
    /smacks forehead/
    I guess I should learn to read.
    Newbie TaZMaNiaK's Avatar
    Jan 2005
    pa
    If you are familiar with the XM interface for the XM Direct, it is probably the exact same software front end - I have it, and I love it.. Very easy to use, and it does everything you've heard it does.. The SIRI version uses a Kenwood KTC-SR903 Sirius hideaway tuner, which normally attaches to a Kenwood head unit. Looking at the picture, there is a "To Controller" port, which is the same DIN-8 connection that the XM Direct uses. Assuming this is a regular RS232 serial connection like the XM Direct, all they have to do is change the XM adapter pin configuration to match it.
    Jan 2005
    pa
    Timetrax front end
  1. A SIRIUS discussion about controlling SIRIUS with a computer.
    By fromplanetbob in forum Hardware Development
    Last Post: 03-26-2005, 07:35 PM
  2. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 04:55 PM
  3. maybe we wont need a sirius pc solution....
    By SWC in forum General Hardware Discussion
    Last Post: 02-16-2005, 11:22 AM
  4. Sirius Satellite solution for PC?
    By Bailey in forum Wireless Communications
    Last Post: 11-23-2004, 05:35 PM
  5. Sirius Carputer solution in the works??
    By biglips31 in forum General Hardware Discussion
    Last Post: 11-18-2004, 12:20 PM
