Results 1 to 5 of 5
Thread: Movie Audio Quality through carputer
    Ne0
    Ne0 is offline
    Jan 2005
    Hi guys, pretty new to the board, but have been scowering it for weeks for info. My 2005 TSX is on order, and I plan on using the AVElectronics switcher to connect my Carputer to the stock navi. In the meantime, Im ripping movies like crazy to Divx in anticipation. I am using Dr. Divx to encode them, keeping the AC-3 audio track, and encoding at 1500 bit rate. My question is, how good of audio are you guys getting with your carputers? I notice when I encode the movies, the volume is pretty low, even though the audio is at 48000 htz, and sometimes like 450 bit rate. I use BSplayer to boost the db which really help alot, but in general how to movies sound out of carputers? Also, is this a good way to encode movies for car use?
    Variable Bitrate drait's Avatar
    Dec 2004
    NorCal
    Assuming you're going to run the sound through an amp, it'll sound just fine. If you're thinking of using the line-out of the CarPC directly to the built-in head unit, it may not sound all that great (unless the OEM deck has a hefty built-in amp). The DVDs that I've ripped for my kid sound just fine, even with downmixed 5.1 to 2ch stereo.
    Newbie John M's Avatar
    Nov 2004
    Milledgeville, GA
    I use AC3Filter to play the movie audio tracks on my rips and it sounds great. It's got a mixer section that you can use to boost the movie volume to equal your normal music levels.
    2005 Subaru Legacy GT
    Status: 40% - starting install
    • AMD Sempron 3100, Biostar K8NHA PRO mobo, 512 meg DDR, WD 200 gig SATA, Opus 150, Xenarc
    • JBL GTi 6.5 fr, JBL 5.25 rr, (3) JBL 75x2 & 1 1200x1 amps, PA MOFO 12 sub
    Ne0
    Ne0 is offline
    Jan 2005
    your talking about BSPLayer to boost the audio? I use that player and the boost is really good...at least on the pc
    Newbie Nighty's Avatar
    Jan 2005
    Leuven, Belgium
    Audio tracks on ripped DVDs always have a low volume; that's why most rippers normalize the sound afterwards. All you need is some application that allows you to edit the audio track. For regular .wav (I always downmix to stereo) there's tons of apps, I assume there must be something similar for AC3 as well, but I wouldn't know what application that would be since I have no experience with AC3.
    Or you could just live with the fact that you'll always have to crank up the volume for your movies, and turn it down again when you wanna play mp3s or CDs... After forgetting to turn down the volume when switching from music to movie a couple of times, you'll soon be incorporating the "normalize" step as part of your ripping routine, trust me...
  1. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 06:34 PM
  2. Your Audio System And Carputer What U Got?
    By kickercivic1 in forum General Hardware Discussion
    Last Post: 12-10-2004, 11:39 AM
  3. Replies: 2
    Last Post: 12-09-2004, 01:03 PM
  4. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  5. Complicated Audio Quality Problem
    By StangBoyCIC in forum General Hardware Discussion
    Last Post: 12-17-2003, 04:05 PM
