from ftdi tech support, FYI
Vincent,
I suspect both your device have the same serial number. This can be confirmed by plugging in one device at a time and using USBVIEW to view the serial number.
http://www.ftdichip.com/Resources/Utilities/usbview.zip
To change the serial number of one device you must uninstall the current driver using Control Panel > Add/Remove Programs.
Install the D2xx driver:
http://www.ftdichip.com/Drivers/FT23...Win/D10620.zip
Install MPROG and use the default template provided.
http://www.ftdichip.com/Resources/Ut...g230_Setup.zip
Uninstall the D2xx driver using Control Panel > Add/Remove Programs.
Re-install VCP driver for both devices and 2 distinct COM ports should be allocated.
Regards,
LinkBack URL
About LinkBacks
