Results 11 to 20 of 28
Thread: Can I recover a crashed hard drive?
  1. #11
    Nov 2003
    Illinois, USA
    you can take a hard drive and throw it into the freezer.. after its very cold, hook it back up. there is also software called "Get Data Back"
    they have it for fat32 and ntfs drives.
  2. #12
    Low Bitrate bd3521's Avatar
    Jan 2004
    NJ
    http://www.runtime.org/gdb.htm
    works like a champ
    carputer: in progress
    Laptop install
  3. #13
    Jan 2004
    NYC
    Quote Originally Posted by bd3521
    works like a champ
    YEP, this software is the ****, I once wiped out my "My Documents" Partition - it had about 20gigs of my pics, with about 7000+ MP3s
    I got everthing back with this software
  4. #14
    Low Bitrate Mush's Avatar
    Dec 2004
    UK
    Hi
    I had a similar problem a while ago. I tried using ontracks data recovery but had no luck as the drive wasent even showing up in my computer so this is what i did
    Leave the drive alone for a couple of days and then hook it up as a slave and reformat it (ntfs, but remember what type of format it was previously most likly fat 32) tried using Ontracks data recovery Format revovery option nad got back over 80% of my work,
    Hope this helps, you could also tru the follwing shaking the hard drive hard, freesing it overnight as the last options only
  5. #15
    Maximum Bitrate Seth's Avatar
    Jun 2004
    Athens Greece
    There are three scenarios :
    1) Hard disk controller failure
    2) Controller halts self registering procedure due to a controller boot failure or because a monitoring parameter gone out of range
    3) Platter/motor/head physical damage that prevent the heads to align and thus the controller to complete the power on control sequence
    Since you probably opened the disk casing and found no evidence of physical damage of the platters and since the disk shows itself on the BIOS with a scrambled name, it is very possible that the controller is damaged. This could be a result of a power surge that caused firmware corruption. Your best chance is, as others already stated, to swap the controller with one from another IDENTICAL drive and test.
    DO NOT USE THE FREEZING METHOD before you make sure it isn't your controller's fault. The freezing method is used in cases of platter - head come in physical contact. The metals will shrink when become cold leaving space for the stuck head to move but only as long as the metals are cold. When the metals reach room temp again they will expand and create micro-fractures on every metal surface rendering your drive unusable and unrecoverable by ANY method.
    Keep us posted.
  6. #16
    Dec 2003
    Germany
    The clicking sound you dexribe sounds like the HDD is overheated. I oticed that many times with the IBM drives I have in my PC. Simple solution is to freeze the sucker and take care that it is ventilated enough. Afterwards hook it back up and you should be ready to go...
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
  7. #17
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    Don't forget that if you get a spec of dust on your playyer when replacing parts, you're going to have an entirely new problem. Plus, if there I micro-fractures on the platters from contact, you can't see them and your data is still probabaly gone.
    Hind sight is 20/20 but another lesson to back up important data. DVD media and drives are so cheap now. I have all critical files on DVD and my media files are all on my 30gig mp3 player (it's doeasn't like trying to play pictures and word documents but it will hold them.)
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
  8. #18
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    Quote Originally Posted by dodgetimes2
    You might be able to swap parts with another IDENTICAL drive.
    NO
    Quick! To the Popemobile!
  9. #19
    Katy TX
    Had this problem before. 2 Solutions:
    1) Hit it on the side. THE SIDE. Not the top, or the bottom. THE SIDE. Hard. Several Times.
    2) Put it in the freezer for about 30 minutes.
    Not even joking, this will get your platters spinning again.
    You might wanna back up your data ASAP as it probably wont last long after this.
  10. #20
    Maximum Bitrate dodgetimes2's Avatar
    MI
    Quote Originally Posted by BiohazrD
    NO
    Platter swapping has been done many times with identical drives.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  1. dead hard drive...
    By tapper1999 in forum General Hardware Discussion
    Last Post: 11-09-2005, 12:31 PM
  2. Hard drive vibration/shock solution? NoiseControl No Vibes
    By slushieken in forum General Hardware Discussion
    Last Post: 08-13-2005, 08:19 AM
  3. Help!!! laptop hard drive
    By ashbosh in forum General Hardware Discussion
    Last Post: 07-15-2005, 02:34 PM
  4. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 11:37 PM
  5. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 08:21 PM
