Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Can I recover a crashed hard drive?
  1. #21
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Swapping platters in identical drives is not something the average user should even attempt. You risk damaging the platters and heads even more. If you can get an identical drive, swap the controller card instead. No need to open up the drive at all to do this. Some of the later drives I've worked on use pressure contacts to interface with the chassis. No tiny connectors to mess with. If the controller isn't the problem then there's really no way to get the data back unless you're willing to spend some really serious money with a data recovery company.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  2. #22
    Registered User
    May 2003
    Quote Originally Posted by BiohazrD
    1) Hit it on the side. THE SIDE. Not the top, or the bottom. THE SIDE. Hard. Several Times.
    I have done this a few times on a customers HDD. It does work sometimes, worth a try out of desperation.
    If you do really need your stuff then dont try this, go and get it recovered properly. Just incase you smash your HDD into bits
  3. #23
    trdcpu's Avatar
    Feb 2004
    Colorado
    Fudge it, keep your hdd in a safe place, and wait about 10 years. this fudging problem will be solved in the meantime. fudge sounds really good right about now.
    behold the future
  4. #24
    trdcpu's Avatar
    Feb 2004
    Colorado
    Had this problem before. 2 Solutions:
    2) Put it in the freezer for about 30 minutes.
    Not even joking, this will get your platters spinning again.
    You might wanna back up your data ASAP as it probably wont last long after this.
    hhahahahahhahahahahahhhhhahhahah you russian cosmonauts are hilarious.
  5. #25
    Jan 2005
    Edinburgh, Scotland
    Maxtor 120gb hdd : $200
    5 years old : -$120
    a ton of information : +$5000
    No backup because you were too cheap to buy another drive : PRICELESS!
  6. #26
    n00b 4 life mp3oplecarrier's Avatar
    Dec 2003
    Chatham, UK
    Quote Originally Posted by electronik
    5 years old : -$120
    Harsh!
    ....Yes, I know it has a stupid name, those crazy Japanese!
  7. #27
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Quote Originally Posted by trdcpu
    no, actually those are both legit ways to get your platters spinning again.
    CarPC install is starting to come along again...
  8. #28
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    quick question...i have a drive thats not that old and not that used that i had in the car. i was moving some wires around and it touched the HD, not sure if it hit the controler board or not but i was thinking about seeing if i could find someone that would know where i might be able to get another one...besides buying another drive which is not worth the $ for me...has nothing important on it, just hate to tose it....thanks,
    "WD 80gb 8mb cache special ed"
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. dead hard drive...
    By tapper1999 in forum General Hardware Discussion
    Last Post: 11-09-2005, 11:31 AM
  2. Hard drive vibration/shock solution? NoiseControl No Vibes
    By slushieken in forum General Hardware Discussion
    Last Post: 08-13-2005, 07:19 AM
  3. Help!!! laptop hard drive
    By ashbosh in forum General Hardware Discussion
    Last Post: 07-15-2005, 01:34 PM
  4. Laptop Hard Drive in carputer...
    By Powers in forum Newbie
    Last Post: 05-08-2004, 10:37 PM
  5. Laptop Hard Drive Problems
    By Powers in forum General Hardware Discussion
    Last Post: 04-28-2004, 07:21 PM
