Results 1 to 10 of 13
Thread: Does anyone know if something like this exists?
    Aug 2004
    I would like to connect my CarPc to my laptop via USB, and I would like the OS to recodnize it like a Mass storage device, meaning I will be able to see my CarPc HD on my laptop as it was DiskOnKey, I know there are cables that support file transfer over USB, but I'm talking about somthing else... some kind of a driver \ software that will set my carpc to act like diskonkey...
    thanks in advance,
    Asaf.
    Variable Bitrate HybridMike's Avatar
    Orlando, Florida
    create a shared drive/folder. and If you set up the carPC and the laptop to have the same network you will see the drive as a network drive
    Aug 2004
    Yeah I know that, I'm searching for something else, the reason is, I have 3 differnt networks that I work with, and I would like to use it on other computers as well, the great thing about this solution is that you dont have to "install" \ configure anything on the other computer, so If I configure my laptop to be "diskonkey" evey other computer that I will connect to will see my HD...
    anyway thanks for the replay... have any other thought?
    FLAC Chairboy's Avatar
    Jan 2004
    The USB transfer cable is still your best bet. You might have to set up a share the first time, but after that, it'll work the way you describe.
    Chrysler 300 - Fabricating
    http://hallert.net/
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The only other solution is get one of the 2.5" USB2/Firewire enclosure and take out the labtop HD whenever needed.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Jan 2004
    Quote Originally Posted by MatrixPC
    Question, why do you call it a 'laBtop'? I see this all the time on this board, and it puzzles me.
    http://hallert.net/
    Feb 2004
    North Aurora, IL
    guessing its a typo
    Jan 2004
    If so, it's a pretty darn consistent one. There are 24 matches, two of which are MatrixPC.
    http://hallert.net/
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    well, use a usb-housing for your hdd (be it laptob or 3.5) and a 2-way switch (maybe a relay hooked up to your serial port, so you can do it in software). Like this:
    ----usb---- CarPC
    HDD ----usb----- switch/relay <
    ----usb--- socket(square) ----usb-cable---- lapdop
    The switch only needs to switch the 2 data wires...
    Just an idea
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by Chairboy
    Yes, sometime my index finger is faster than my little finger.
    but the fastest of all is the middle one
  1. Why MediaEngine exists...
    By CarComp in forum ME Archive
    Last Post: 06-02-2003, 08:39 AM
