Results 11 to 20 of 25
Thread: manualy turn off inverters?
  1. #11
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
  2. #12
    a diode is a diode.. its just if you have a diode thats too small.. it might go pop =P
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  3. #13
    Maximum Bitrate fantomas's Avatar
    Nov 2003
    CT
    you could put a relay on the power line and turn that on and off manually in order to completely shut off power to the inverter
    rebuilding carpc... kinda..
  4. #14
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    well first, i have 2 inverters and neither one of them have a switch to turn them on/off just plug them in and they are on. So.... ill have to find on that has a switch. I think i can manage to relocate the switch without much hassle. Im not to sure about the other stuff.
    Thanks for all the info guys. will let you know if i fry myself once i get a new inverter.
  5. #15
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    I use a vector 400W inverter and we took the LED display/on-off/select feature and moved it up to the front of the car using some cat3 6pair. the put the LED display where my clock used to be and wired the buttons differently so it was easier to access them. I can take some pictures if you'd like. Also it's easy to see what the voltage is on my battery, as well as how much power it's using.
    -David
  6. #16
    Maximum Bitrate hd54321's Avatar
    Jun 2004
    Los Angeles
    fyi - you could also purchase a time-delay relay. Check this one out - you could connect it to your computer and it will shutoff the inverter after the computer shuts off. It even has timing adjustments. It's also priced relatively well (i.e. not over-priced).
    -HD
  7. #17
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Why not just wire a relay to control the inverter?
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  8. #18
    Aug 2003
    Federal Way, WA
    or just a switch.
  9. #19
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Or just dont turn it off. But then you'll want an aux battery.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  10. #20
    Aug 2003
    Federal Way, WA
    Quote Originally Posted by n8scstm
    Yeah you will!! If I don't unplug mine the battery is dead by morning. And I
    don't mean the computer, the inverter on with computer off.
  1. Navigator Turn by Turn V2
    By CRCinAU in forum GPS
    Last Post: 08-08-2004, 06:49 PM
  2. Replies: 4
    Last Post: 03-25-2004, 06:53 AM
  3. Remote turn on: 2 Amps + EQ
    By jspeeder9 in forum Power Supplies
    Last Post: 10-20-2003, 02:07 AM
  4. Inverters - what to look for?
    By noodles in forum Power Supplies
    Last Post: 09-27-2003, 11:30 PM
  5. Replies: 0
    Last Post: 07-23-2002, 12:45 AM
