Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: manualy turn off inverters?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Just a quick question, for you guys using power inverters in your cars.
    How do you turn the thing off? Are you manually unplugging it every night as to not suck the bat dry or somthing else?
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Quote Originally Posted by liquid_smoke
    Mine came with a remote on/off switch. Just ran it up to behind the driver's seat.
    I think it's pretty easy to open up an inverter and add one, too.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I run mine through a relay that is connected to the acc line from my ign. So the inverter powers up when I start the car, and I built a delay circuit to turn it back off when I turn the car off.
    肚子笑痛了
    S60 Install
    Aug 2003
    Chicago
    Quote Originally Posted by VanMan69
    this is exactly what i need, do you have a link to the inverter you have. Its getting to be a super pain to unplug mine every night, esp since im only using it to power the lillyput. I looked into powering the lillyput from the opus but sounds like its too involved for me.
    Constant Bitrate cbergeron's Avatar
    Or you could just use a startup/shutdown controller to turn the inverter/computer on and off with the vehicle ignition; and never have to worry about the inverter draining the battery.
    Even when switched off, some inverters' cooling fans still run. In someplace like Arizona or Florida, you'd have a dead battery in no time - even with the inverter turned off.
    DashPC - The Linux Car (since 1999).
    Dash LCD, Via Epia, GPS, XM, OBDII, DSSC Shutdown Controller.
    As seen in the book Geek My Ride
    May 2004
    Alameda, CA
    Well, this is my inverter:http://www.donrowe.com/inverters/aims_1250.html
    Don't remember where I bought it.
    It's 1250W, though. A little excessive if you're just running your Lilliput. You'd be better off wiring it to your Opus, or just extending the on/off switch on a smaller inverter. Hooking it up to your Opus really isn't that difficult.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Most inverter will have a switch to turn it on/off.
    Just wire another swith either parallel or serie to the location of your liking. I prefer serie or just extend the switch.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Feb 2004
    Orlando, FL
    I jsut opened up my inverter and disconnected the switch that is hooked up and ran some cables to the front of my car and mounted a switch up front to turn on and off. But I just ordered a Car PC EZ 2.2 so that is old news.
    Pioneer DEH7600MP, Autotek MX-800.4, JL Audio XR650-CSi, Adire Audio Shiva
    Done with CarPCs, using a iPaq 3765 PDA w/ Holux GM210 and TomTom
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    do a search you'll find a shut down controller that uses a relay and a diode. BUT no one ever knows what fricking size diode to use, so you're on your own there.
    I'm at work but when i get home i can send you the link to the thread, PM me, if you cant find it.
    lol you can always just use a big diode.. its not going to really hurt anything =)
    Carputer HIFI car stereo project!
    [XXXXXXXXXXXXXXXXXXXXX-]
    95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
    [XXXXXX--------------]
    30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
  1. Navigator Turn by Turn V2
    By CRCinAU in forum GPS
    Last Post: 08-08-2004, 05:49 PM
  2. Replies: 4
    Last Post: 03-25-2004, 05:53 AM
  3. Remote turn on: 2 Amps + EQ
    By jspeeder9 in forum Power Supplies
    Last Post: 10-20-2003, 01:07 AM
  4. Inverters - what to look for?
    By noodles in forum Power Supplies
    Last Post: 09-27-2003, 10:30 PM
  5. Replies: 0
    Last Post: 07-22-2002, 11:45 PM
