Results 1 to 9 of 9
Thread: reccomend a connecor: 14 small wires specs inside:
    Dec 2004
    UK
    Experts recomend a connector!!! 14 small wires specs inside:
    Seperating Laptop screen from the base, but need to connect it back on a daily basis as my only machine and need for in home use too
    format:
    Screen- male end -----> female end long extension cable to male end <--------- - female end Laptop base
    The cable will have 14 wires (5 for screen info and 9 to display adapter- so possible two connectors but would prefer the one)
    Need connectors which is
    1) easily seperable
    2) female end mounts flush on dash OR hangs off but doesnt look cheap
    3) cables are very small so something which won`t be too hard to fit on.
    4) It will be unplugged on a daily basis so something that is hardwearing and doesnt fall apart.
    suggestions?
    Dec 2004
    UK
    Bump
    anyone?
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I still don't get what are you trying to do.
    Are you separating the laptop and its monitor and move the monitor to a different location? If so, it may not work because of length limit for the back light inverter (or whatever it is)
    Or are you using the laptop with a different screen (7" Lilliput, Xernac, ...)? If so, get a VGA extension cable.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    UK
    Yup seperating screen (in its housing) from laptop base.
    should work as extending the wire from the MB to display adapter NOT wire from display adapter to screen
    Doing on a budget so dont want to buy screen, also like the large diamete of current screen
    anyone 14 wire connector recommendaions?
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Good luck getting that to work. Very, very few laptops have monitors that can be moved more that a couple of inches from the lcd controller that is part of the motherboard. And as far as quick connecting and disconnecting, i have no idea how you plan to accomplish that. All I can say is hopefully it isn't a very nice laptop.
    ATVMS.com
    Newbie Milo's Avatar
    Oct 2004
    Sydney
    Ive seen this done once before it was on a compaq laptop and he was able to extend the cables about 40cm
    anyway i know this is an aussie website but it may be of some assistance
    Clicky
    If its not leaking something its not a Holden
    ddn
    ddn is offline
    Dec 2004
    That is why they invented LVDS. LCD monitors can't be far away from their controllers. 95% chance it won't work.
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    Use a DB-15 connector...vga connector.
    CarPC install is starting to come along again...
    Aug 2004
    Mountain View, CA
    I believe Yuriy on these boards used a parallel printer cable if I remember correctly. He discussed it over in the showcase thread for his Saturn. I'm sure he'll be glad to help.
  1. how small can you go pics inside...
    By cdm in forum General Hardware Discussion
    Last Post: 02-29-2004, 11:31 AM
