Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: How to mount circuit in metal case?
    I have built myself a regulator circuit that I want to mount alongside my PC m/b in a custom metal box that I bought. The problem is that there is basically no mounting holes on the circuit board, and even if there were, I can't have screws poking through the bottom of the metal case (I'll be using rivets to hold the m/b mounting plate and the spacers for the m/b screw into that).
    Does anyone know of a cheap and simple approach to mounting this in my case? Can I get some kind of thick double-sided rubber tape to both hold the circuit in place and prevent is shorting against the metal case?
    Here are some pictures.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    looks like you have holes in the board....
    I would mount it to a piece of plastic with MB standoffs and double sided tape the plastic part to the case.
    TruckinMP3
    Read the FAQ!
    Newbie Deviser's Avatar
    May 2004
    Annapolis MD.
    Arathranar,
    You could use a hot glue gun and inject the glue between the board and metal case I have done it before many times it works great and costs pennies if that .
    Deviser
    In progress Carputer [////////||] IWill ZPCgx: P4 2.40Ghz, 512Meg, 40Gb, Xenarc 7" TSV, 5 1/4 slot DVD, 802.11g DWL-G132, Ebay BU-303 USB GPS, TMobile GPRS Internet, Custom made power controller.
    HU-Alpine CDA-7897 Fantom Face XL AM/FM CD/MP3 Receiver.
    Variable Bitrate therussman2002's Avatar
    Mar 2004
    Milwaukee, WI
    i have the same problem with my mobo/reg board/etc in a metal case.. i was thinking of getting a small pack of 1/4" long nylon spacers from menards, with small bolts/nuts, but they dont come in packs, just individual packages, and i couldnt find a number i needed...
    so im awaiting an answer to this quandry as well
    Quote Originally Posted by TruckinMP3
    There are two small holes. They're way too small for standard m/b standoffs and I'm not sure I'm comfortable with only mounting at 2 out of 4 corners. And the holes are tiny and very close to the edges of the board - they just don't look like they'd be very effective if I hit a bump or such.
    Currently the hot glue approach is tempting. Hot glue it to some fairly thin plastic and then I can use rivets to hold the plastic in place.
    Jun 2002
    Colorado
    you could hot glue custom standoffs... that would let a bit of air movement behind the board.
    TruckinMP3
    Read the FAQ!
    That's true. And I'm a little leary of permanently gluing my circuit into the case in case I ever want to remove it and tinker . But that then leaves me with only two tiny holes to mount it with and/or having to drill another two holes in the other corners. Scary stuff... I can just see my carefully built and test circuit (ok, we'll ignore the mark 1 that I blew up by connecting the power in reverse...) dying because I slip with the drill!
    Maybe I'll just hot glue a couple of pieces of wood in place across the entire ends of the circuit board. Then I'll have full support at all 4 corners but could use two small screws to hold it in place.
    Jun 2002
    Colorado
    That sounds like a good solution.
    TruckinMP3
    Read the FAQ!
    Jan 2005
    Edinburgh, Scotland
    Best is to get some M4 nuts, countersunk head bolts, and washers. find space on the board where you can mount three or four of them, near the corners preferably. Drill holes in the board (don't be a sissy, just be carefull). Hold the board against the box and mark off the positions of the holes. Drill out the box, then countersink the other side. Fit the bolts thru, then screw them on with a nut and washer to the case. Next, fit on another two nuts locked together on all the bolts, so as to give a good standoff height. Finaly, slide on the curcuit and bolt it down with a final nut and washer. This is a bombproof way of doing it, but it's simple and cheap. Use a smaller guage of bolt if M4 is too big (I can't remember off the top of my head).
  1. Found a perfect case!
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-08-2006, 09:12 PM
  2. Do we need a metal PC case or is plastic OK?
    By -al- in forum General Hardware Discussion
    Last Post: 09-17-2003, 10:27 AM
  3. Looking for a case...
    By gork in forum General Hardware Discussion
    Last Post: 08-05-2003, 01:02 AM
  4. Replies: 0
    Last Post: 07-14-2003, 03:12 PM
  5. custom making a case
    By ares in forum General Hardware Discussion
    Last Post: 03-12-2003, 08:38 PM
