Results 1 to 10 of 13
Thread: Accelerometer ... anyone use one ???
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I have read through the threads and there is allot of mention of accelerometers, but I didn't come to any where they actually followed through with them.
    seems that phidjets has some, and there are some rather pricey ones out there.
    I would like to implement one as a moving/stopped indicator to disable video etc .. Frodoplayer has this function included ( Frodo ) ... and it seems that the liablility if these things are ever sold and there isn't something there is huge. Plus, having one that is difficult to disable would be nice ( hard, not impossible )
    Also, seems like they all have way too much capability. They could even duplicate one of those dashtop boxes to measure horsepower etc ... with the proper software ( maybe an addon to ODBII functions )
    It would be nice to find one that is simple moving / stopped ...
    anyway, just rethinking this and wonder if there has been any development
    Don
    Registered User
    May 2003
    Why not just use the handbrake to disable the video?
    Use the speedometer? or even use the GPS (not very reliable though)
    The accelerometer is not really that reliable for measuring true acceleration of the car. Rather it measure the total acceleration felt by the sensors, thats including the gravity. Go and buy one, tilt it up and you see it register 1g. Put the car on a hill and you see it register some acceleration even though the car is parked up. A bump on the road will see a change in acceleration and I dont think theres a way to remove this easily. Hit a bump once, a small acceleration is registered and it may continue seeing the car travellling at some speed even though you have already stopped.
    There is a long thread about this, dont know if you already read it.
    Jan 2003
    Ruston, LA
    Accelerometer would suck for this.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by frodobaggins
    yeah and it would mean if your car was rocking for some reason the video would go off. Accelerometers would be useful added into your GPS system for when it loses signal.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Scouse Monkey
    Not really. You really need a compass and a speed sensor.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Mar 2004
    Bristol
    you can take your last recorded speed and direction from GPS and use a couple of acclerometers to detect changes. Bit basic but might help in built up cites.
    Mar 2004
    Bristol
    a digtial compass would save bit of work though
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    i agree with this, an accelerometer isnt going to tell the differance between stopped and constantly moving at a particular speed, it also has no relavence to horsepower unless you factor other things in like weight
    Signature: [==||========] 20% complete
    Mar 2004
    Bristol
    i suppose you could always tell the cinrcuit to assume the car is stationary when it is turned on. then it can calculate the speed easily from that. But a handbrake sensor a billion times easier.
    Maximum Bitrate DeltaFX's Avatar
    France
    One can filter a 2D accelerometer to get rid of gravity effect. The idea is to making it move just like it was on top of a joystick pushed forward->left->back->right(am I clear ???)
    1-If the system is horizontal, not moving or @ stabilized speed, then the output graph is a circle, centered on (0,0)
    2-If the car is on a slope, not moving or stabilized speed, the output is still a circle, but no longer centered on (0,0)
    3-If the car accelerates/decelerates/turns, the pattern is a egg-oïde, offcentered like the circle in case 2(its gives the slope) and its great axis minus the original circle radius gives the real planar accélération.
    The problem is tilting the sensors.....
  1. Replies: 103
    Last Post: 02-07-2005, 10:56 AM
