The board is made my VIA that's about the only thing they have in common. That's a big motherboad, not an ITX formfactor.
http://www.newegg.com/app/ViewProduc...150-016&depa=1
would this have about the same power consumption as an m10000? if so this things got the case and psu too....for the same price as an m10000
PC Components:
My work log
it looks like the same size to me. I have an xpc formfactor board, and its bigger then that board. If you look at the picture it looks just like an itx board. Another thing it has in common is the single pci slot. Though its not stated, i'm pretty sure this IS a mini-itx. Also this board has the same processor as the m10000.
PC Components:
My work log
Looks like a flex-ATX board. A bit larger than mini-ITX. Most, if not all, SFF boards are flex-ATX.
Similar power requirements I am sure, I was looking at that when I got me small form factor stuff, but I needed TV out, and I have dealt with trying to get a proprietary thing like that from a different manufacturer, it wasn't pretty.
The board itself is 50mm longer, has more USB 2.0 ports (6 versus 4), two ram slots instead of 1.
I don't know if has the same onboard video with MPG2 acceleration or not.
ok well its not the eden processor, but i couldnt imagine the power draw being much more
PC Components:
My work log
funny you say that about video, under expansion slots it says 1x PCI, 1x TV Out, doesnt look like that in the picture. i wonder what they mean by 1x tv out expansion slotOriginally Posted by Bangster
PC Components:
My work log
probably just an svideo or RCA header on the mobo or a small slot like and AMR slot to put a back panel tv-out into.Originally Posted by Peoples
Originally Posted by Scouse Monkey
that's what it looks like. this page shows a card you can add that has the tv-out and dvi.
nice link
PC Components:
My work log
