Results 11 to 20 of 22
Thread: Toyota Rain Sensing Windshield Wipers
  1. #11
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Quote Originally Posted by 0l33l
    Would help knowing what car you have.
    One problem with your idea: POWER! The computer cannot be in standby if the rain sensor is to tell it something. That means that the computer will have to be on from when u start work till when you finish. Not a very good idea for batteries.
    This is not strictly true. With just a little bit of circuitry, it would be possible for the rain sensor to turn on the computer when it need it to do something. Moreover, he didn't mention if actually expected his PC to participate in this at all.
  2. #12
    Maximum Bitrate DeltaFX's Avatar
    France
    Ultraviolet ? Me think it's infrared, UV-sensors aren't that common
  3. #13
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    also, our windstar has a feature similar to this, although i doubt it is based on the rain amount, rather its probably speed based. basically you have to go through a long set of instructions listed in the owners manual to activate it (and you have to reactivate it every time you start the car). more or less it involes changing the ignition state and using the wiper controls and just properly coreographing(sp?) it all.
    Your everyday carpc geek and tech guru at your service. *bow*
  4. #14
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    do some research on qtouch ic's I'm using them for a different applications but the watter on the windshield would cause a change in capacitance and trigger the ic. this would be the sensor...the logic is in your hands, i do like the auto pc power up because you could have it do some other cool things!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  5. #15
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by rando
    True, but that's more complicated...
  6. #16
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Just doing a quick it looks like a glass thing:
    http://www.rainsensors.com/Optical.htm
    http://www.tricoproducts.com/brochur...8&brochure=238
    A whole PIC project:
    http://www.the12volt.com/installbay/...ID=47178&TPN=2
    It would seem to be best if the sensor is away from the wiper area, so it doesn't wipe the rain away and stop working.
  7. #17
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    A rain sensor triggered by actual exposure to water is pretty trivial. http://www.electronics-lab.com/proje...015/index.html I think this is what the original poster was referring to. Of course part of the circuit then has to be outside; I'm thinking along the rain channel just under the hood in front of the windshield.
    Also, a 5 or 10 second 'memory' is simple enough, so that wipers don't interfere with the optical detectors.
  8. #18
    Low Bitrate jbraddoc's Avatar
    Feb 2004
    Lee's Summit, Missouri
    This is going to sound stupid, but Take one of the sprinkler systems rain sensors, modify it to your liking, and put it in the cowl of the car, so when it rains, it will trigger a relay, that you can take the solid signal, and convert it into a pulse, and have it pulse the window roll up module...
    edit: but, it would have to take a bit of water to make the sensor work, which may defeat the purpose of having this. And, you could be driving down the road, hit a splash, it come in the cowl, and roll your windows up.. but heh you could go as far as making it turn your windshield wipers on.. heh
  9. #19
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Quote Originally Posted by jbraddoc
    Thats what I said on page 1.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  10. #20
    Oct 2004
    Quote Originally Posted by grepzen
    Try another approach:
    :: default position of windows == rolled up (security)
    :: when temp (outside) > x then "vent" (roll down) windows 1/2"
    :: when temp < y roll up windows (rain would cool outside temp below y)
    They already have complete kits for this, & you get to set x and y values.
    Unless its a tropical climate. Ha, Fl....
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. Winshield Wipers subforum
    By Banderon in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-19-2004, 01:00 AM
