Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Toyota Rain Sensing Windshield Wipers
    Apr 2002
    Houston, TX
    Have you guys seen the Avalon comercial where they mention wipers that come on automatically when it starts to rain????
    Pretty cool....
    I have been mulling over a simlar idea for a few years now, except I want the windows to be put up when it rains and the car is parked at work.... I leave the windows down in the summer when I am at work.... I hate a 150 deg car experience at the end of the day....
    But in Texas it can (and will) rain at the drop of a hat... without warning....
    Doing a Google search for "rain sensor" it is easy to make a little PC board and circuit to sense the rain..... and then power up the window motors, etc....
    But I was wondering if anybody knew how Toyota did it with the Avalon..... a nice clean system would be cool...
    Anybody know?
    Oct 2004
    NY
    one clue I can give you is that lexus has the rain sensor built into the windshield, bmw, benz & jag, infiniti do the same......haven't looked into this further, but they all have sensors that are built into the windshield. I have seen add on aftermarket(dei maybe?) rain sensors though I think, start searching high end security accessories....good luck..........
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Would help knowing what car you have.
    One problem with your idea: POWER! The computer cannot be in standby if the rain sensor is to tell it something. That means that the computer will have to be on from when u start work till when you finish. Not a very good idea for batteries.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Ive seen sensors that sense water that are used for sprinkler systems. It turns them off in the rain. Its basically a sensor hooked to a relay. If you could get ahold of one of those you could make your own circuit pretty easily.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    i remember seeing an old car show on TNN where they were showcasing a device which was basically a sensor mounted on the inside of the windshield behind the rear view mirror and it was wired into the wiper system and essentially did what the avalon does, but on cars that cant. beyond that, i have no clue about the product.
    one thing i can suggest as far as power is concerned (which ive seen someone else here suggest) is to have the computer running all the time (or atleast the times you wish the rain sensor to do its work), and have the computer wired to the ignition so that it will start the car every 5 minutes or so and run it for a couple minutes to keep the battery charged.
    Your everyday carpc geek and tech guru at your service. *bow*
    FLAC djmickyg's Avatar
    Feb 2004
    i work for bosch and bosch makes em .. i neer thought of getting a hold of one to play with
    there all mounted on the windscreen, maily behind the rear view mirror. it looks like a dark purple/blue arear thats maybe 5cm square.
    they work by emiting ultraviolet (i think ultraviolet) like onto the windscreen and when the window is dry the layers on it will be flat the light will reflect off the top surface and bounce back at the unit and it knows there is no rain
    when rain falls on the area on the sensor the light goes true the window into the ball of rain and cus the rain ball is round not flat it is reflect off an on a different agle and the unit wont pick it up sencing there is rain.
    the more light that is not reflected back the heaver the rain is
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Quote Originally Posted by djmickyg
    I think this is correct. My wife's Chrysler 300 has this feature as well. The harder it rains, the faster the wipers go.
    ATVMS.com
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    For power: I wouldn't go though the carputer for this. There's really no need, the logic is so simple (rain -> close power window button circuit for x seconds,) the computer is superflous. You don't even need a PIC. The rain detector tied to a timer circuit tied to a relay should do the trick. The idle power draw will be pratically nill (and you could probably make it actually nill if you wanted.)
    I'm planning on adding a rain detector, but rather than auto-up the windows, it'll be tied to a remote control to sound an alarm to my desk at work - I have a manual-top convertable, so windows by themselves aren't going to do much good
    Oct 2004
    NY
    Hmm, I guess I just assumed the rain sensor was built into the windshield because I have changed quite a few, & I know that you must specify whether the vehicle has rain sensor or not, I'm used to seeing defrosters built in to winshields as well as anntennas, so I just assumed..............but after thinking about this further I realize that although the winshields are different, it's just to accomodate the rain sensor mounted behind it.
    sorry for the miss-information I guess I just didn't pay enough attention to the actual rain sensors, although I do remember one car did have a strange box type thing attached to the mirror mounting area, that must have been the rain sensor.......
    Maximum Bitrate grepzen's Avatar
    Jul 2004
    VaBch VA
    Try another approach:
    :: default position of windows == rolled up (security)
    :: when temp (outside) > x then "vent" (roll down) windows 1/2"
    :: when temp < y roll up windows (rain would cool outside temp below y)
    They already have complete kits for this, & you get to set x and y values.
    •Micke
  1. Winshield Wipers subforum
    By Banderon in forum Mp3car Forum Suggestions/Comments
    Last Post: 04-19-2004, 01:00 AM
