Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Voltage Regulator Constant Heat
  1. #11
    Constant Bitrate BassBinDevil's Avatar
    Nov 2004
    Vancouver Island, B.C.
    The regulator could be oscillating; they can do that when there's no load on the output. Try putting a small capacitor across the output, like 0.01 to 0.1 microfarads. One across the input wouldn't hurt either.
  2. #12
    Jan 2005
    When not connected to mp3 player, the current draw is 300mA ---> 3.6W, with mp3 player, its over 500mA (off ammeter's scale)
    The 7805 I have has the plastic coverings and has the markings ueML (mu epslon M L) then under it 7805A.
    I tried putting a .1uf capacitor on the input and output, and it didn't reduce the heat.
  3. #13
    Jan 2005
    I went to another local radio shack and found the exact same model of 7805, identical umEA print on it.
  4. #14
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Unless you're willing to get one from another source, I wouldn't worry about the unloaded heat. It's still operating within normal specs when loaded. The temp isn't that bad as long as the space you put it into isn't too small and you already have it heatsinked. Try the install and monitor it closely for any signs of overheating the first few uses.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
  5. #15
    Jan 2005
    OKOK I'll take it up the ... from shipping. What online store can a voltage regulator that doesn't make my heatsink sizzling to the touch?
  6. #16
    Variable Bitrate mp3hombre's Avatar
    Aug 2002
    Montreal / Los Angeles
    How have you wired it up?
  7. #17
    Jan 2005
    Quote Originally Posted by mp3hombre
    The input souce is a DC wall adapter that puts out 7.5V 800ma
    Pin 1 - input 7.5V wire
    Pin 2 - ground wire from the input, and ground wire to output
    Pin 3 - output wire 5V
  8. #18
    Jun 2004
    Idaho
    You may want to try hooking up 12v from your battery as the power input. The 7805 will output 1A or 1000mA. It may be working too hard to regulate the output with only 800mA coming in.
    Rick S.
  1. Replies: 7
    Last Post: 01-14-2005, 10:56 AM
  2. What Gauge wires do I use?
    By Showmehow in forum Newbie
    Last Post: 07-25-2004, 10:41 AM
  3. Voltage issues with ITPS?
    By mcrussell in forum Power Supplies
    Last Post: 06-06-2004, 10:48 PM
  4. ITPS and Voltage drop issues
    By Wiredwrx in forum Power Supplies
    Last Post: 04-20-2004, 06:09 AM
  5. DC-DC psu and high capacity HDD
    By GrahamS in forum General Hardware Discussion
    Last Post: 12-19-1999, 05:44 PM
